removing fuel line - Kawasaki ZX-10R.net
post #1 of 14 Old 05-01-2012, 08:14 AM Thread Starter
logmaster's Avatar
removing fuel line
why is it always such a fight?
isnt the correct procedure to push in the solid orange part
push fitting towards tank then pull it off?
orange thing doesnt want to push in
thought I'd vent here before I break it
logmaster is offline
post #2 of 14 Old 05-01-2012, 09:25 AM
SkyDork's Avatar
Pushing it in? The red banding pulls out. I use a small flathead screwdriver to lift it off and then just pull the line off. Its easy.
The red (orange if you want) has 3 full sides and on the last side is just a couple of little tabs that hold it down. Put the screwdriver under the complete side opposite the 2 tabs and lift it up. It doesn't come all the way off, just lift it until those tabs reach the other side of the connector. Nothing pushes in that I've dealt with?
#WordCrimes
SkyDork is offline
post #3 of 14 Old 05-01-2012, 09:46 AM
Kawawog's Avatar
Send a message via MSN to Kawawog
Originally Posted by skydork View Post
pushing it in? The red banding pulls out. I use a small flathead screwdriver to lift it off and then just pull the line off. Its easy.
The red (orange if you want) has 3 full sides and on the last side is just a couple of little tabs that hold it down. Put the screwdriver under the complete side opposite the 2 tabs and lift it up. It doesn't come all the way off, just lift it until those tabs reach the other side of the connector. Nothing pushes in that i've dealt with?
Kawawog is offline
post #4 of 14 Old 05-01-2012, 10:44 AM
Does not drive into smoke
El Zilcho's Avatar
Lol. ...And my impression was that this is one of the easier things to disconnect.. I guess we all have different experiences.
The idea is that you need to squeeze the orange tabs towards each other, then push them in so that the other side comes out. You can actually move the tabs one at the time with a screwdrive or something, just enough so that they don't lock back in place. Once you get that, the rest is easy. When pulling the line off the tank, hold it through a rag or paper towels---there will be some gas coming out.
El Zilcho is offline
post #5 of 14 Old 05-01-2012, 07:12 PM Thread Starter
logmaster's Avatar
thanks guiys
it's like those friggin electrical connections, squeeze the little tab? lift the little tab? is there a tab on both sides?
it really doesnt have to be made that difficult, does it?
post #6 of 14 Old 05-01-2012, 09:01 PM
SkyDork's Avatar
Originally Posted by logmaster View Post
thanks guiys
No. You don't squeeze the tab. Look at the red band around the connection. Look at it on all the sides. One side is not complete. It looks like a claw. Spread the claw apart at those little tabs and slide the red square over the connector. Then just pull it off. I don't have any pics, but it's really that simple. Look at it again.
Sent from my iPad using MO Free
#WordCrimes
SkyDork is offline
post #7 of 14 Old 05-01-2012, 09:58 PM
El Zilcho's Avatar
Which gen is this? On gen 1 it's exactly the opposite.
post #8 of 14 Old 05-01-2012, 11:09 PM
Darmentle's Avatar
Yeah pulls out. Make sure when you are putting the clip back on the little tongs on it line up. It had me scratching my head last weekend lol.
Darmentle is offline
post #9 of 14 Old 05-01-2012, 11:16 PM
easy to take off, pain in the a** to put back on.
BronxRR is offline
post #10 of 14 Old 05-01-2012, 11:39 PM
alkaline nine's Avatar
Missed the tongs once, gas everywhere during cranking.
alkaline nine is offline
Gen 1: WANTED Orange Fuel Line Clip hellsrazor Wanted: Buy or Trade 1 04-19-2011 10:53 PM
Need fuel line red retaining clip Candy08 Wanted: Buy or Trade 2 11-17-2009 10:16 PM
Clutch Cover "New" 06-07 ZX10R, Brembo Lever, Fuel line Dry brake, Exhaust Cam 4 SELL JimmyJam Parts, Gear and Accessories 3 09-18-2007 11:51 PM
installing power commander '05 zx10r... disconnect fuel line from bottom of tank? CaFFeineSouLja Performance and Tech 13 02-14-2007 04:01 AM
Help needed in disconnecting fuel line marco383 The ZX-10R 4 05-20-2004 03:10 PM
