Removing front wheel - Kawasaki ZX-10R.net
post #1 of 14 Old 10-29-2007, 01:09 PM Thread Starter
russell's Avatar
Looks like about a 21-22mm allen wrench is required, any idea where i can get one?
russell is offline
post #2 of 14 Old 10-29-2007, 01:12 PM
SecretAgent's Avatar
Send a message via AIM to SecretAgent
don't need it. leave the two pinch bolts tight on that side, and loosen the two on the other side of the axle. then loosen the axle and remove. no need to mess with the allen wrench side at all.
SecretAgent is offline
post #3 of 14 Old 10-29-2007, 02:58 PM Thread Starter
russell's Avatar
i have the allen on both sides of my axle so that won't work.
russell is offline
post #4 of 14 Old 10-29-2007, 07:16 PM
Retired post whore
Alien10's Avatar
I found some stuff like that at Sears - craftsman tools.
Alien10 is offline
post #5 of 14 Old 10-30-2007, 01:23 PM Thread Starter
russell's Avatar
i still can't get the front wheel off. do you guys know the size of the allen wrench is that is needed to remove the front axle nut?
russell is offline
post #6 of 14 Old 10-30-2007, 01:39 PM
FAF
Rent this space
Couldnt tell you for a 6R , the 10R has a 14mm Allen one side and 22mm hex head on the other.
FAF is offline
post #7 of 14 Old 10-30-2007, 02:03 PM
kawiiiiii's Avatar
Images: 19
Why didnt I think about that.
kawiiiiii is offline
post #8 of 14 Old 10-30-2007, 07:33 PM Thread Starter
russell's Avatar
another question. i've managed to get everything off, just need to mask some stuff for the powder coating. my question is when i put the wheels back on is it necessary to torque them specifically?
russell is offline
post #9 of 14 Old 10-30-2007, 08:19 PM
Big Daddy's Avatar
Images: 38
most certainly!! rotors, axle, bottom fork pinch bolts, calipers, etc.
Big Daddy is offline
post #10 of 14 Old 10-30-2007, 08:29 PM Thread Starter
russell's Avatar
i dont see why i would need to torque the bolts that hold the rotors on to a specific ft/lb. same with the calipers, it's just some bolts that hold it to the forks.
russell is offline
Removing rear wheel to take in for new tire... curiousmike Performance and Tech 2 09-07-2007 01:44 AM
Leave bike in neutral when removing front sprocket? curiousmike The ZX-10R 14 08-11-2007 08:07 PM
removing wheel weight adhesive Older Guy The ZX-10R 50 07-04-2006 01:42 AM
removing wheel bearings??? on1whl Performance and Tech 2 04-18-2006 04:23 PM
removing the front wheel Older Guy Performance and Tech 2 05-22-2005 10:33 PM
