Gen 4: 2011-2015 Removing Cat - Kawasaki ZX-10R.net
post #1 of 13 Old 03-30-2011, 06:38 AM Thread Starter
ggenovese's Avatar
Removing Cat
I am in the process of installing my Graves exhaust on my bike. I have removed the exhaust, but the bolt that holds the catalytic converter will not budge. Any suggestions? Thanks in advance.
ggenovese is offline
post #2 of 13 Old 03-31-2011, 06:21 AM
VICKO's Avatar
I have no problem removing cat from mine gen4. So I think you must try harder...
VICKO is offline
post #3 of 13 Old 03-31-2011, 06:23 AM
Dont mess wit White Ninja
abzx10r's Avatar
I'm just going to assume your both talking about the pre muffler box not the cats because I'd also assume the cats are inside your headers!
Take your time, get it on a stand and it shouldnt be a problem!
abzx10r is offline
post #4 of 13 Old 03-31-2011, 09:24 AM Thread Starter
ggenovese's Avatar
Weird. The bolt wont move. It feels like if I twist any harder I'll strip it. The only reason Im leary is that I already stripped 2 bolts. The two bolts that hold the 2 bars that hold the fender eliminator to the subframe. It feels like whomever put this bike 2gether used power tools and locktite. :( I have an appointment Saturday for the shop to back the bolts out if they can. They are charging me $90 to drill through the holes and loosen/remove the bolt that holds the cat canister to the frame. Any suggestions in helping me save my $90
post #5 of 13 Old 03-31-2011, 10:46 AM
SkyDork's Avatar
WTF??? They can't just hit it with an impact wrench for you for like $10? That's ridiculous. You need to break the locktite free with an impact wrench or a long breaker bar and a hammer. Even a manually operated impact wrench (the kind that you hit with a hammer while holding it) should break it loose. Take that $90 and go buy yourself the tool to do the job. Then you'll own the tool and the next time you need it you won't have to pay someone else.
#WordCrimes
SkyDork is offline
post #6 of 13 Old 03-31-2011, 10:52 AM
derrickd's Avatar
what state are u in
maybe some one on here can help u out
derrickd is offline
post #7 of 13 Old 03-31-2011, 12:38 PM
timhanley156's Avatar
If you're in Northern California, I'll be able to help you, man.
timhanley156 is offline
post #8 of 13 Old 03-31-2011, 02:33 PM
05KzX10r's Avatar
Might be an obvious question but did you try and soak it in wd40 and let it sit for a few hours?
05KzX10r is offline
post #9 of 13 Old 04-02-2011, 10:25 AM Thread Starter
ggenovese's Avatar
No i didnt but im gonna try and spray some on it today. Thx. Im in Richmond VA
post #10 of 13 Old 04-02-2011, 11:22 AM
05KzX10r's Avatar
I had to do that to my exhaust manifold on my SRT before. Sometimes it works. Sometimes it doesn't. Let me know if you have any luck with it.
05KzX10r is offline
removing air box codyc_13 The ZX-10R 7 03-16-2008 08:15 PM
Removing gas cap -No Key Bigtuna660 The ZX-10R 35 11-04-2007 07:00 PM
Removing Cat what map will i need ? Speedyj Performance and Tech 7 11-16-2006 02:18 AM
Removing your CAT smason5 Performance and Tech 19 08-20-2006 11:32 PM
Removing Gauges fastbikesrule Performance and Tech 6 03-25-2006 07:09 AM
