Removed motor today - Kawasaki ZX-10R.net
post #1 of 28 Old 12-27-2005, 09:24 PM Thread Starter
Removed motor today
Well took me 3 1/2 hours to get motor out, head off and both surfaces clean and ready to go back together. Thin head gasket is here but cam is on back order, which sucks. Will get the head back on tomorrow.
Bently is offline
post #2 of 28 Old 12-27-2005, 10:25 PM
Supercharged Mod
Fast worker!
GoFaster is offline
post #3 of 28 Old 12-27-2005, 10:29 PM Thread Starter
I work at a kawasaki/suzuki dealer part time so I have acess to the shop and lifts so it helps a lot. Not a bad job to take out though.
Bently is offline
post #4 of 28 Old 12-28-2005, 05:09 AM
1bad7's Avatar
Images: 13
any special tools needed, for this removal? I will be doing it soon for a buddy who broke his frame when it hit a wall.
1bad7 is offline
post #5 of 28 Old 12-28-2005, 07:37 AM
Nice job. I ordered a thin head gasket from Muzzy friday. Are you going to do anything to the head? Valve job? Porting? I have 8200 miles on mine and was debating if I should have the a valve job done on it. Any special tools requiered in the removal?
I am going to degree the cams to 107/104 per Muzzy specs also.
Tell your girlfreind I said thanks
otto is offline
post #6 of 28 Old 12-28-2005, 09:20 AM
Ninjaeric's Avatar
Take some pics if possible!!!
Ninjaeric is offline
post #7 of 28 Old 12-28-2005, 03:17 PM Thread Starter
really no special tools needed except one socket that has what i call four legs to back off the jam nuts on a couple of the motor mounts. No head work for me, the zx10 heads are ported by hand at the factory so unless someone really knows what they are doing gains will be min. 5 angle valve job might be worth a little but not enough for me to worry about.
Bently is offline
post #8 of 28 Old 12-28-2005, 05:20 PM
41ants's Avatar
You work at a shop part-time and it took you 3.5 hours. I wonder how many hours they would tell you to bill the job at for a customers bike?
05' ZX-10R (sold)
03' 954RR Titanitum/Black (sold)
41ants is offline
post #9 of 28 Old 12-28-2005, 06:36 PM Thread Starter
And I did not rush doing it, pretty straight forward removal. Just wish the cam would show up not that I'm in a hurry with all the snow we have but would like to get it back together.
Bently is offline
post #10 of 28 Old 12-28-2005, 08:35 PM
rocketracermike's Avatar
you should open your owen shop.
rocketracermike is offline
Has anyone removed a battery from the 10R? RichTJ99 Performance and Tech 10 07-26-2011 03:08 PM
HP Gain with Kleen Airr removed? Floyd Performance and Tech 11 07-08-2005 01:07 AM
Has anyone removed the undertail from the tail? zx102nv The ZX-10R 14 01-26-2005 06:17 PM
PICTURES of Dan Kyle plates installed, KLEEN/AIS (Cali-bike) removed STREETFIGHTER50 Performance and Tech 13 10-31-2004 01:41 PM
Who had Akro with name badge removed Finatic-1 The ZX-10R 20 05-26-2004 11:29 PM
