remaping a powercommander - Kawasaki ZX-10R.net
post #1 of 10 Old 05-15-2011, 12:31 PM Thread Starter
petesgrnzx10r's Avatar
i have a 05 zx10 i had the commander mapped and tuned for a 2 brothers slipon standard size i jus recently had the can shortened to i have to remap and dyno cuz i had this done or can it still run on exsisting map and tune
petesgrnzx10r is offline
post #2 of 10 Old 05-15-2011, 12:49 PM Thread Starter
cmon any1 lol
post #3 of 10 Old 05-15-2011, 12:57 PM
BlackFire's Avatar
you should be able to run on the existing map, obviously what that will do is reduce your backpressure a bit...but how much depends on how much you had cut down. a few inches shouldn't affect you much at all...the more ya cut down, the more it may affect your tune, while moving the power band up the rev range just a bit. dunno how serious you are about having the bike at it's extreme tip top tuning, but as long as it's only a few inches cut down, should be ok. personal preference tho if you want to take it in and have it remapped, but no, not something you will "have" to do.
People often mistake my patience for laziness.
BlackFire is offline
post #4 of 10 Old 05-15-2011, 01:17 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
you'll be fine, cutting a few inches off the exhaust canister does not or will not affect anything that has to do with tuning or back pressure.i've cut down cans and tuned countless bikes myself too but i wouldn't even think about a dyno tune unless you're running a full exhaust with a few mods and want to get every single ounce of power out of the bike or if you have that kind of cash to throw around.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #5 of 10 Old 05-15-2011, 01:19 PM Thread Starter
i cut 9 to 9.5 inches off the can you think a remap will be in order for sure for that much?
post #6 of 10 Old 05-15-2011, 01:43 PM
TMY10ER's Avatar
Not really, i know guys who run open headers at the strip and they use the same map as when they run their street set up. run the bike and see if there are any dead or flat spots thru the rpm's n rev range. that will tell you 110% for sure.
TMY10ER is offline
post #7 of 10 Old 05-15-2011, 01:52 PM Thread Starter
as your ridin at a steady idle i get a poping out the exhaust idk if thats normal cuz its so short now and i dont notice any power loss or misfire like you think its cool
post #8 of 10 Old 05-15-2011, 02:22 PM
TMY10ER's Avatar
you can always get rid of the "popping" on decel or backfire by doing this....pg2 for the 1st gen
https://www.zx-10r.net/forum/showthread.php?t=79926
TMY10ER is offline
post #9 of 10 Old 05-18-2011, 01:32 PM
BlackFire's Avatar
yea getting rid of the air injection will help that...but i like the popping if it's not too overly done. 9-10 inches will effect the pressure in the exhaust, but again, who knows how much...may be neglegable. best advice is like tym10er said, feel for flat spots and/or lean areas and see how she rides. if you're happy with it still, you're golden. but if you have the money to spend and care enough to squeeze every last bit of potential out of the setup you have...by all means. dyno it up. but with the stock headers and exhaust servo and same air filter...etc...as before the tune, you should be fine!
post #10 of 10 Old 05-18-2011, 01:42 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
That popping on the decel is because of the emission controls.
That thread that TMY10ER gave you will tell you how to install smog block off plates that will stop the popping.
hellsrazor is offline
06-07 Powercommander photodigm1 Parts, Gear and Accessories 3 12-24-2010 06:17 AM
Trying to get a powercommander blackstars_10 The ZX-10R 18 08-10-2009 12:03 AM
PowerCommander III USB F/S 08/09 kneedrgn04zx10 Parts, Gear and Accessories 2 07-27-2009 03:02 PM
powercommander DANGER10R Parts, Gear and Accessories 5 03-07-2006 10:50 AM
Powercommander calhounzx10 Parts, Gear and Accessories 7 07-19-2005 12:07 AM
