regulator rectifier - Kawasaki ZX-10R.net
post #1 of 6 Old 10-05-2006, 08:52 AM Thread Starter
Rock_Star's Avatar
Exclamation Regulator Rectifier !!
Is there any way to test this to see if its going bad?
Under low RPM's Im getting flashing or no gauges...
(just got a new battery)
thanks...
Rock_Star is offline
post #2 of 6 Old 10-05-2006, 09:36 AM
lavudyar's Avatar
Send a message via Skype™ to lavudyar
RR is supposed to be a Honda problem!
Ray D
Never pet a burning dog.
lavudyar is offline
post #3 of 6 Old 10-05-2006, 09:40 AM
ZX10C2's Avatar
dosn't sound like a regulator rectifier. chech the charge rate should be aound 13v. maybe loose plug / treminal some where. give us some more info
ZX10C2 is offline
post #4 of 6 Old 10-05-2006, 09:47 AM Thread Starter
Rock_Star's Avatar
its acutally for my wifes, 99 R6.
just replaced the battery 3 days ago.
checked the ground to the frame, looked good.
Didnt see any loose/woren wires....
post #5 of 6 Old 10-05-2006, 07:34 PM
Here's a link to a step-by-step fault-finding flowchart for motorcycle charging systems. I've used this before (I'm certainly no electrical system expert!) to successfully diagnose a bad regulator/rectifier (not on my 10, though):
http://www.electrosport.com/electros...t_finding.html
I hope this helps!
GD
Green Dude is offline
post #6 of 6 Old 10-09-2006, 06:56 PM
10rmotor's Avatar
Put a voltmeter on the battery with the engine off. Then start it. You should see about a 1.5V increase with the engine running, around 14.5 volts. If it doesn't increase then the battery isn't getting charged. If the alternator is internally regulated you will have to replace the entire unit (assuming all wiring is good). The 10R has an external reg so its easier to replace. HTH.
10rmotor is offline
Volter Regulator? special k Performance and Tech 4 09-12-2006 08:20 AM
