Gen 1: 2004-2005 Regearing question??? - Kawasaki ZX-10R.net
post #1 of 16 Old 04-07-2012, 12:39 AM Thread Starter
Heavyweight's Avatar
Im looking to regear to a -1 front and +2 to +5 rear. What top speed losses can I expect? would it still be suitable for long rides on the highway? What is everyones thoughts on which setup would be best to regear to? thanks
Heavyweight is offline
post #2 of 16 Old 04-07-2012, 01:13 AM
MUSHU's Avatar
Don't have any experience with that much change in the rear, but here is something where you can play with the different gears. http://www.gearingcommander.com/
MUSHU is offline
post #3 of 16 Old 04-07-2012, 01:19 AM
BigCat for Prez!
BigCat10R's Avatar
-1,+5 is slightly more aggressive than -2,+2 which I run and I top out at 160ish. On freeway 90mph is abt 7-8k I think. if ur SWB I wouldn't recommend that aggressive of a setup bec ull flip in a heartbeat if ur not careful. This is more for 1/4mi
-1,+2 is great ull top at abt 175ish and the rpms aren't too much higher than stock at freeway speeds. this setup will wheelie better than stock but is still manageable at SWB
BigCat10R is offline
post #4 of 16 Old 04-07-2012, 01:27 AM
Licensed Dist of HaterAde
TMY10ER's Avatar
I've ran -1/+2 on the last few sport bikes I've had and it's perfect for me :)
TMY10ER is offline
post #5 of 16 Old 04-07-2012, 06:06 AM
Gen2 Ripper
neverendingmods's Avatar
If you are not stretched don't bother with -1/+5 gearing. You wont be able to use all the power in first and second gear because bike will want to flip over quick.
-1/+2 is a great gearing especially if you do a lot of high speed highway runs and stock wheel base.
neverendingmods is offline
post #6 of 16 Old 04-07-2012, 10:19 AM
zx racer's Avatar
i ran -1 +2 when i was swb and i liked it very well... went low 6's in the 1/8 with that gearing... now im -2 +2 and it woke the beast up even more.
zx racer is offline
post #7 of 16 Old 04-07-2012, 01:42 PM Thread Starter
Yeh i am SWB and am looking for something a little more aggresive, plus i like to wheelie :) im either thinking -1 +2 or -2 +2
post #8 of 16 Old 04-07-2012, 01:48 PM
zx racer's Avatar
-1+2 will be plenty enough. -2 +2 if you plan on stretchin it.
zx racer is offline
post #9 of 16 Old 04-07-2012, 02:08 PM Thread Starter
Im thinking -1 +2 it will be, thanks guys
post #10 of 16 Old 04-07-2012, 03:12 PM
Hi i went for +4 rear and it is a little higher gearing than -1+2, check gearingcommander. You get better wear than -1+2. you will need a longer chain.
Hobbe is offline
520 conversion and regearing question ikaika Performance and Tech 10 03-11-2009 12:02 AM
Passenger peg question/mid pipe flange question KawieKrazy The ZX-10R 0 08-12-2008 07:42 PM
