Rearset problem - Kawasaki ZX-10R.net
post #1 of 26 Old 11-01-2008, 07:31 PM Thread Starter
ZX-10R enthusiast
dudewhrsmybike's Avatar
Rearset problem
Bought these from another member a few months ago, somehow they worked for him, I'm just not getting it. . . .Can't get rear master cyl linkage to connect to rear brake pedal
This is what they are supposed to look like. Doesn't the bracket with 4 holes look completely different than what I have?
dudewhrsmybike is offline
post #2 of 26 Old 11-01-2008, 08:40 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
you can unsrew that bolt so its longer
Lucky10R is offline
post #3 of 26 Old 11-01-2008, 08:48 PM
MIA Ex-Mod
Tread70's Avatar
I don't see that as the problem, the master either needs to move out or the lever needs to move in for a proper alignment.....
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #4 of 26 Old 11-01-2008, 08:51 PM
Lucky10R's Avatar
Images: 19
i see that too.
but look at the pic at the bottom.. it matches perfectly.
I suspect that you are using the wront heel guard mounts..
you prolly swtiched left/right.
Lucky10R is offline
post #5 of 26 Old 11-01-2008, 08:53 PM
GEN II Driver
ripper's Avatar
there is a spacer that goes in the location where your mentioning. i circled it for you. the linkage off the mc should adjust down to meet the connector on the right side. if not then maybe you switched sides like lucky said.
MDCCLXXV
ripper is offline
post #6 of 26 Old 11-01-2008, 09:02 PM
Lucky10R's Avatar
Images: 19
ripper is prolly right too.
That mount you have for the MC is still OEM.
Most aftermarket one have a "spacer" with a bearing at the end.
Lucky10R is offline
post #7 of 26 Old 11-01-2008, 09:22 PM Thread Starter
ZX-10R enthusiast
Its out all it will go.
I have the spacer.
Look at this pic, this is the only way it will line up, look how low the brake lever is
Nothing is switched. Look at this pic.
post #8 of 26 Old 11-01-2008, 09:23 PM Thread Starter
ZX-10R enthusiast
My idea was maybe to come up with a way to lengthen the threaded bolt that goes into the MC?
post #9 of 26 Old 11-01-2008, 09:38 PM Thread Starter
ZX-10R enthusiast
Check this out, the one on the left is OEM. But get this, the one on the right for these rearsets fits over the back of the rear brake pedal but if you look in the picture from their website I posted, they don't have it connected that way, it is connected off to the side. WTF?
post #10 of 26 Old 11-01-2008, 09:41 PM
Postwhore with an 04
bcm0018's Avatar
I recently installed satos. There is a different end that goes on the master cylinder and there is a spacer to fill the gap.
bcm0018 is offline
Rearset yellow10r The ZX-10R 11 02-01-2008 02:11 PM
Help... Need an 06 Right Rearset SpazOnaZX Parts, Gear and Accessories 4 03-09-2007 06:02 PM
'06 Rearset Help! SkyDork Performance and Tech 20 03-04-2007 04:41 AM
right rearset.... vettewreck ZX-6R & ZX-6RR Archives 0 02-05-2007 12:06 PM
Rearset set-up TN10 The ZX-10R 4 09-10-2005 10:32 AM
