rear shock spring questions - Kawasaki ZX-10R.net
post #1 of 6 Old 11-11-2008, 03:30 PM Thread Starter
dirt ninja's Avatar
Images: 9
first question: Are ohlin springs compatible with penske shocks? (i believe they are but wanna confirm this)
second question: How do i figure out what number to look for if i need a spring for 160lb rider? (i have a spring on my shock but dont know what weight its sprung for as i have looked all over the spring and couldnt find it anywhere including the very bottom.) Ive been looking at other springs and they have 8.0 and stuff like that but its greek to me.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #2 of 6 Old 11-11-2008, 07:40 PM
greenman43's Avatar
Images: 33
The 8.0 you mention will be the spring rate, in kilgorams per mm ; that is, for each 8kg of force applied, the spring will compress by 1 mm.this equates to around 448 pounds per inch. The conversion rate is a.56 ; that is, kg permm times 56 = pounds per inch.
Cheers,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
post #3 of 6 Old 11-11-2008, 08:36 PM Thread Starter
dirt ninja's Avatar
Images: 9
thanks for the info brian.
post #4 of 6 Old 11-12-2008, 12:38 AM
greenman43's Avatar
Images: 33
No worries mate, sorry I can't help on the compatibility. Spring weight is heavily dependent on your own weight, but also on intended use ; as an example, I weigh around around 215 pounds at the moment (fat bastard !) and use a 9.5 kg/mm on the track. I'm told that may not be heavy enough, but as i prefer a sift spring it seems to work well for me.
All the best,
Brian
post #5 of 6 Old 11-12-2008, 10:25 AM Thread Starter
dirt ninja's Avatar
Images: 9
All the best,
Brian
I found what i was looking for brian. I was looking for a spring calculator and found it here.http://www.racetech.com/evalving/Spr...pringType=Fork
post #6 of 6 Old 11-14-2008, 04:56 AM
greenman43's Avatar
Images: 33
Great thanks, I knew I'd seen one somewhere previously :)
Cheers,
Brian
Rear Shock Spring compressor afskypilot Performance and Tech 0 04-28-2008 09:47 AM
zx14 rear shock/spring on my 10 Jeckylll Performance and Tech 6 11-14-2007 08:02 AM
Factory 05 rear shock spring rate? Vince10R Performance and Tech 4 06-16-2007 09:12 PM
Have a question about new spring for rear shock? medicdad2005 The ZX-10R 0 02-21-2007 03:29 PM
Looks Like I'll Need A New Rear Spring Or Shock............. SP8 The ZX-10R 7 08-19-2004 02:24 AM
