Rear Shock Shim ? - Kawasaki ZX-10R.net
post #1 of 6 Old 01-11-2008, 11:50 AM Thread Starter
lyketobyke's Avatar
Rear Shock Shim ?
ID:	55657Hi -Y'all - Newb to ZX10R.net here !!!! I bought a used '06 ZX10R and am about to install an aftermarket shock. There is what looks like a shim between the shocks top mount bracket and frame. Is this factory or has the previous owner installed this ? Any and all feedback much appreciated - thanks !
lyketobyke is offline
post #2 of 6 Old 01-11-2008, 11:54 AM
kawi1000's Avatar
Images: 26
Originally Posted by lyketobyke View Post
Attachment 55657Hi -Y'all - Newb to ZX10R.net here !!!! I bought a used '06 ZX10R and am about to install an aftermarket shock. There is what looks like a shim between the shocks top mount bracket and frame. Is this factory or has the previous owner installed this ? Any and all feedback much appreciated - thanks !
Yes it's factory and .
kawi1000 is offline
post #3 of 6 Old 01-11-2008, 12:10 PM
Big Daddy's Avatar
Images: 38
like the ninny said its OEM and depending on what aftermarket shock you purchased you may want to remove the shim or leave it.
Big Daddy is offline
post #4 of 6 Old 01-11-2008, 12:23 PM Thread Starter
lyketobyke's Avatar
OH - NO Options !!!! I think i'll leave it , thanks
post #5 of 6 Old 01-11-2008, 12:36 PM
Images: 9
Sometimes you need to remove it. Depending on what else you change. The shock manufacturer should be able to tell you. I know when I went from a 55 to 50 tire I changed mine to correct for the geometry change.
ZXTEN-R is offline
post #6 of 6 Old 01-11-2008, 12:44 PM
kawi1000's Avatar
Images: 26
Different tire manuraturer has different profile too my DC III I've added 3mm with mine, can't wait to try it :mrgreen.
kawi1000 is offline
Removing rear shock shim (adding trail) ?? OmegaX Performance and Tech 17 10-04-2006 10:32 PM
Removing Rear Shock Shim TheReb Performance and Tech 15 07-02-2006 05:14 PM
Rear Shock???????????? SP8 Performance and Tech 19 01-26-2005 04:35 AM
Rear Shock Again ZX10BURNER Performance and Tech 4 01-13-2005 06:16 PM
WTB '03 and up 6R/6RR or ZX-10R rear shock pacmann33 Parts, Gear and Accessories 5 10-02-2004 01:24 PM
