Rear shock removal, socket size?? - Kawasaki ZX-10R.net
post #1 of 12 Old 05-24-2007, 02:34 PM Thread Starter
OmegaX's Avatar
I need to know what size socket to get to remove the bolt at the top of the rear shock. Its the bolt that has a cotter pin through it, located under the fuel tank hinge. I looked through the manual but can't find it.
OmegaX is offline
post #2 of 12 Old 05-24-2007, 02:37 PM
Images: 7
trial and error. think of it this way you will build up your socket set honestly I have no idea.
shenanigans is offline
post #3 of 12 Old 05-24-2007, 02:52 PM
Big Daddy's Avatar
Images: 38
me thinks its a 17mm but not 100% sure.
Big Daddy is offline
post #4 of 12 Old 05-24-2007, 02:57 PM Thread Starter
OmegaX's Avatar
Thanks BD but It is larger than 19mm and smaller than 27mm.
OmegaX is offline
post #5 of 12 Old 05-24-2007, 03:14 PM
Big Daddy's Avatar
Images: 38
i should have read with both eyes instead of one... as i thought you referred to the one that bolts the shock to the clevis brkt.
i know your referring to part# 92015 but still not sure of its size however if its larger than 19mm it must be 21mm.............i think.
http://www.ronayers.com/fiche/400_05...parent=139 10
post #6 of 12 Old 05-24-2007, 03:20 PM
ducatiryder89's Avatar
Images: 21
You don't need to remove the top nut!!!!!!!!! Look underneath it there's the 14mm nut and bolt that holds the shock in place. The nut with the cotter pin is for the upper shock mount.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #7 of 12 Old 05-24-2007, 03:23 PM
Images: 21
But if you insist on removing the top nut its a 23mm
post #8 of 12 Old 05-24-2007, 03:31 PM Thread Starter
OmegaX's Avatar
I should of been more clear on my objective. I am removing the shim. Thanks for everyones quick response
OmegaX is offline
post #9 of 12 Old 05-24-2007, 03:31 PM
Big Daddy's Avatar
Images: 38
dang it 2 strikes.............only 1 left.
post #10 of 12 Old 05-24-2007, 09:13 PM Thread Starter
OmegaX's Avatar
Everyone was wrong, it is 22mm and you need a deep socket. I got lucky and bought a set like shenanigans said to do. Removing the shim is kinda a pain in the ass, not hard just a pain
OmegaX is offline
06 ZX-10 Rear shock removal? sxi Performance and Tech 30 02-14-2007 10:29 AM
What size socket? exntrick The ZX-10R 7 01-13-2007 03:06 PM
Socket size for main nut on steering tripple Dare-x Performance and Tech 16 09-28-2006 07:50 AM
What size Socket hangman39 Performance and Tech 9 03-20-2006 12:35 PM
Oil FIlter socket size Louks03 Performance and Tech 0 07-21-2005 08:19 AM
