rear shock install - Kawasaki ZX-10R.net
post #1 of 6 Old 07-04-2005, 04:22 PM Thread Starter
a
rear shock install
Today i finnaly got my ohlins rear shock. The question is how hard is it to remove stock shock and replace it. Is it 1man job or is beter to go to service and let them doit.
What is the torque on shock bolts up and down?
First unbolt downside of shock or uper bolts?
a is offline
post #2 of 6 Old 07-04-2005, 09:32 PM
lavudyar's Avatar
Send a message via Skype™ to lavudyar
You'll need f/r stands, jack stands and 14mm & 12mm tools. You will need to unbolt the linkage as well, but only the pivot bolt, in order to get shock in/out. It really makes not much difference what order you go in but I did the bottoms then the top. It took me less time to change the shock than it did for me to get that stupid cs sprocket nut off!
Bolt torque #'s are - shock mounts top and bottom @ 81ft/lbs and the pivot bolt @ 72ft/lbs.
Ray D
Never pet a burning dog.
lavudyar is offline
post #3 of 6 Old 07-05-2005, 03:59 PM
I think those torque values are too high it is either 43ft lbs or 25ft lbs.
Yep, place jack stands under your rider peg hangers, and use a rear stand slowly remove the rear stand to ensure the bike is held by jack stands...then swap em.
BNninja is offline
post #4 of 6 Old 07-05-2005, 04:54 PM
Big Daddy's Avatar
Images: 38
1) top shock nut is 43ft-lbs
1) bottom shock nut 81ft-lbs
2) swingarm pivot linkage arms 72ft-lbs
heres a pic of one way to lift the rear end so your able to raise/lower the swingarm/wheel as needed.
Big Daddy is offline
post #5 of 6 Old 07-05-2005, 05:00 PM
lavudyar's Avatar
Wow - I found 2 different number for torque. I thought the upper/lower shock mount numbers looked high, but the manual says 81ft/lbs on pages 397/398. Then on 415 it says 25ft/lbs. I think there's a problem with the labling on the exploded view - the names don't match the parts, which I should have picked up on but didn't.
Ray D
lavudyar is offline
post #6 of 6 Old 07-05-2005, 05:02 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
I just got my friend to balence the bike on the kickstand...
James 3:7,8
hillcountry10r is offline
Stock 04 ZX10R rear shock trackaddict Parts, Gear and Accessories 3 03-08-2005 06:05 PM
WTB: Stock ZX-10R Rear Shock Servility Parts, Gear and Accessories 1 02-08-2005 01:03 PM
Rear Shock???????????? SP8 Performance and Tech 19 01-26-2005 03:35 AM
Gregg's Rear Turn Signal Install step by step w/pics>> jeech The ZX-10R 11 01-23-2005 11:30 PM
Anyone know price on Ohins rear shock? steves87 The ZX-10R 12 11-01-2004 03:23 PM
