Rear Shock???????????? - Kawasaki ZX-10R.net
post #1 of 20 Old 01-25-2005, 04:49 PM Thread Starter
SP8
SP8's Avatar
Does our bike have a rear shock spacer where it attaches to the frame? Like the 03/04 ZX6R.
SP8 is offline
post #2 of 20 Old 01-25-2005, 04:54 PM
Big Daddy's Avatar
Images: 38
it does have a 3mm spacer/washer thats sandwiched between the top shock brkt & frame.
Big Daddy is offline
post #3 of 20 Old 01-25-2005, 05:03 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
Talking
Takes about 20 min to remove if you've gotta strong and willing buddy.
James 3:7,8
hillcountry10r is offline
post #4 of 20 Old 01-25-2005, 05:04 PM
burgerkin's Avatar
SP8 you do have a 10R? So walk over to your bike and take a look...
but BD is being to nice again....
burgerkin is offline
post #5 of 20 Old 01-25-2005, 06:26 PM Thread Starter
SP8
SP8's Avatar
Hey man, your talking to the King of laziness.
SP8 is offline
post #6 of 20 Old 01-25-2005, 06:48 PM Thread Starter
SP8
SP8's Avatar
Next question. I'm short, and obviously lazy. I don't want to lower the bike too much, but I figure taking out the washer will help. If I measure from a fixed point on the subframe to the ground with the washer in. Then do the same measurement with it out. Then measure from a fixed point in front of the frame to ground. Then pull my forks up until I get the same difference in height as removing the washer did in the rear. That should give near the same geometry right?
SP8 is offline
post #7 of 20 Old 01-25-2005, 06:54 PM
Big Daddy's Avatar
Images: 38
In the shadetree/coonass schoolin it will. Actually try removing the 3mm shim and leaving the frontend alone until ya ride it! then if your so inclined to raise the tubes have at it.
post #8 of 20 Old 01-25-2005, 07:27 PM Thread Starter
SP8
SP8's Avatar
I could do that. I was planing to drop the front before my pulling the washer idea. Wanted to taste a little quicker steering. But your method may save me some work BD.
SP8 is offline
post #9 of 20 Old 01-25-2005, 08:11 PM
I think BNinja did something w/ the rear shock spacer. There was a reference to the geometry change 3mm rear == 4.5mm front. So if you remove the 3mm rear shock spacer, sounds like raising the forks 4.5mm in the clamps would bring you back to stock geometry.
SuicideMachine is offline
post #10 of 20 Old 01-25-2005, 08:16 PM
Big Daddy's Avatar
Images: 38
I removed my spacer as well but the Penske is 4.5mm longer eye~eye than the stocker so the end result is still +1.5mm
Rear Shock Again ZX10BURNER Performance and Tech 4 01-13-2005 05:16 PM
Anyone know price on Ohins rear shock? steves87 The ZX-10R 12 11-01-2004 03:23 PM
Spacer on Rear Suspension Mounting! vane The ZX-10R 2 06-05-2004 05:05 PM
Rear Hugger with 180/55-17 Rear Tire CanyonCarver The ZX-10R 15 04-21-2004 04:55 PM
R1 150 rear wheel. CDRacingZX6R Archives 15 01-12-2004 09:36 PM
