Rear Sets - is there a need to fabricate return springs - Kawasaki ZX-10R.net
post #1 of 12 Old 07-17-2005, 05:24 PM Thread Starter
circusnuts's Avatar
I installed a set of Woodcraft rear sets this weekend, or should I say "still installing them" :headshake (instructions are very vague), and I noticed this type of an upgrade requires the loss of the rear brake pedal return spring.
So far I don't like the return rate as well as the stock rear sets.
Has anyone else missed having the return spring after moving to aftermarket rear sets (or is this something that typically feels better over time) and/or made the modifications to incorporate it again?
Thanks
Phil
Dress for the slide & not the ride
circusnuts is offline
post #2 of 12 Old 07-17-2005, 05:32 PM
Big Daddy's Avatar
Images: 38
My Attacks have no spring and function just fine without it.
Big Daddy is offline
post #3 of 12 Old 07-17-2005, 05:36 PM
Ara
LE Post Whore
Ara's Avatar
Graves motorsports has a return spring, you can check that out. www.gravesport.com
Not sure if it will fit the 10, but given that most bikes use the same rear master cylinder, it should work.
Ara is offline
post #4 of 12 Old 07-17-2005, 07:32 PM
Trust me, you'll get used to not having the return spring. You shouldn't be using the rear brake hard enough to care about return rate anyway.
SuicideMachine is offline
post #5 of 12 Old 07-17-2005, 09:10 PM
avdigigeek's Avatar
I never noteced w/ my vortex either...
Smiley
nesba # 936 http://www.nesba.com/
CCS # 936 wingnutzracing.com
Sponsors
Twisted-powersports.com
DCDECALS.net
http://ask2geeks.com/
http://www.superbikeitalia.com/
"Being shot out of a cannon will always be better than being squeezed out of a tube.
That is why god made fast motorcycles"
Hunter S. Thompson.
avdigigeek is offline
post #6 of 12 Old 07-17-2005, 09:11 PM
Green Hippie
treyzx10r's Avatar
no return spring on the sato set works just fine
VAE VICTUS!
treyzx10r is offline
post #7 of 12 Old 07-17-2005, 11:27 PM
MIA Post Whore
miykl's Avatar
My Gilles have no return spring. Aftre seeing another poster use a o-ring as a return spring I did some experimientaion (wow I put a lot of letters in there- too much Crown tonight). Anyway, I put the bike on a swing arm stand, pressed the rear brake and released, then spun the wheel. I found that the rear brake was dragging some. I used a large o-ring as a return spring and repeated the test. The rear wheel spun more easily. A added bennifit was I found the rear brake easier to modulate with the added tensension (feel). I think I may try the Graves spring as it would be more clean.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #8 of 12 Old 07-17-2005, 11:30 PM
Post Whore
El Diablo's Avatar
Nice lookin' set-up... Here's a direct link for those interested.
http://www.gravesport.com/cgi-bin/sh...on&key=BK__039
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #9 of 12 Old 07-18-2005, 12:40 AM
Post Whore
El Diablo's Avatar
Moved to tech...
El Diablo
post #10 of 12 Old 07-18-2005, 07:00 AM
the R1 part from gravesis for a brembo master cylinder...the n10r has that huge black rubber thingy and is over 1/2" in diameter. I talked to phil yesterday and there isnt' anything you can do unless you have attack, gilles or sato. Use another bolt in the adjustable portion and attach a rubber band as seen in wstaab's pics of his bike.
BNninja is offline
Woodcraft Rear Sets circusnuts The ZX-10R 0 07-15-2005 08:00 PM
Stock rear sets / mint trackaddict Parts, Gear and Accessories 3 03-28-2005 10:13 PM
In search of sato rear sets treyzx10r The ZX-10R 21 02-04-2005 03:43 PM
my original rear sets icepack The ZX-10R 25 01-22-2005 09:30 AM
Muzzy Rear Sets!!! Ryan Schnitz Vendors deals 14 12-21-2004 06:53 AM
