Rear sag question. - Kawasaki ZX-10R.net
post #1 of 7 Old 02-13-2010, 09:05 PM Thread Starter
nickalltogether's Avatar
Rear sag question.
Going crazy in the house I decided to attempt to set the sag on my 08. I was able to get the front sorted, it now has 6 lines showing and about 28mm of sag with me on it with no gear. The rear I could only get to 15mm or so... is this right? I turned the collar out a decent bit and made no real progress that I can tell. Thoughts?
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #2 of 7 Old 02-13-2010, 10:16 PM
Somatic Healer's Avatar
I follow a general rule of 25mm for the street because of the bumps. Usually 25mm is a good starting point at the very least. You can set you sag at whatever you want, however you're comfortable. Some people like to ride a little faster and may have theirs set stiffer. I weigh 230 am 6.0' tall and i can still use all my tire running the on and off ramps with 25 mm of sag.
Somatic Healer is offline
post #3 of 7 Old 02-13-2010, 10:28 PM Thread Starter
I had read that 30-35mm was a good starting point for street and 25-30mm was good for 'race' bikes. In a later piece I came across there was information indicating I should be going for about 25% of total suspension travel. I am going to redo it all again before I go to ride it next.
2005 Honda F4i-Red
Commuter stuff
post #4 of 7 Old 02-14-2010, 08:48 AM
Vio
Vio's Avatar
You should be able to get it somewhere around 30mm. I'm not sure why you would only be able to get 15mm
Vio is offline
post #5 of 7 Old 02-14-2010, 09:58 AM Thread Starter
I'm fairly confident I was doing something wrong. I'm gonna regroup and try it again before I ride it again.
2005 Honda F4i-Red
Commuter stuff
post #6 of 7 Old 02-14-2010, 06:57 PM
BANNED
ZX10Rracer's Avatar
tape your soft tape to a point on the bike, the rear should have 0 sticktion so it an easy read!
ZX10Rracer is offline
post #7 of 7 Old 03-04-2010, 01:44 AM
Gday, I have played around with my sag, I'm too fat, I could only get my sag to a certain point and no matter how far I wound the preload down I could not get the right number, consider that your spring needs to be changed
chicken_fart is offline
Setting sag on rear stand? strkd50 Performance and Tech 35 07-02-2009 02:04 PM
Question when setting Sag taxsux Performance and Tech 32 01-08-2009 07:32 PM
rear sag sweetride10r Performance and Tech 1 09-10-2007 06:55 PM
Rear preload/sag Abiagi The ZX-10R 9 10-11-2006 03:01 AM
Attack rear set question-rear brake light switch? steves87 The ZX-10R 35 10-09-2006 04:47 PM
