rear brakes - Kawasaki ZX-10R.net
post #1 of 7 Old 04-18-2008, 09:21 PM Thread Starter
rayszx10r's Avatar
Send a message via AIM to rayszx10r
Need Help With Rear Brakes
I Put New Pads On My 06 Zx10 Today And They Seem To Push Down Farther Than Usual,they Stop Ok,but I Noticed When Im Standing Next To The Bike I Can Here Like A Cracking Poping Type Noise Coming From The Brake Area I Tryed Bleeding Them And They Still Seem To Go Down Farther Than Usual,i Tryed Searching The Topic And Couldnt Find Much On The Situation Any Help Will Be Apriciated,thank You All In Advance.
rayszx10r is offline
post #2 of 7 Old 04-19-2008, 07:39 AM Thread Starter
rayszx10r's Avatar
bump
post #3 of 7 Old 04-19-2008, 06:46 PM
mach_man_187's Avatar
Sorry, no help here, I have not replaced my rear brakes yet......
If you're not living on the edge, your taking up too much space!
mach_man_187 is offline
post #4 of 7 Old 04-19-2008, 07:04 PM Thread Starter
rayszx10r's Avatar
thanks anyways hopefully someone can help
post #5 of 7 Old 04-19-2008, 08:38 PM
curiousmike's Avatar
How Did You Put The New Pads In?
Usually You Need To Push The Pistons Back Out So The New Thicker Pads Can Fit.
If You SomeHow Horked A Piston It's Conceivable It's Not Moving Freely.
You Might Verify Both Pistons Look Reasonable.
2005 Titanium, Hyperpro RSC, Sato Slip On, Champ Frame/Swingarm sliders
curiousmike is offline
post #6 of 7 Old 04-19-2008, 09:48 PM
thrill's Avatar
If the pads are not seated in the caliper properly this sort of thing can happen as you described
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #7 of 7 Old 04-20-2008, 09:17 AM Thread Starter
rayszx10r's Avatar
I Took Calibur Off Then Depressed The Calibur Completly,then Then Took Out Carter Pin Took Out Pads Stuck In New Ones Only Problem Was Thwhen I Was Putting The Little Shaft That Holds The Pads It Didnt Want To Go In The Back Pad Real Easy So I Tapped It Slightly And It Went In Bolted Everthing Back Up,if Ive Done Something Wrong Please Let Me No This Is The Firsrt Time Doing Pads On A Bike Myself.
Brakes Blink180Wilhelm Performance and Tech 32 03-30-2008 09:42 PM
Brakes,rear sets, exhuast etc - 2004-2005-2006 jstwkd1 Parts, Gear and Accessories 62 10-26-2007 02:49 AM
Brakes yellow10r The ZX-10R 1 07-24-2007 06:02 PM
Do the brakes get better? johnny napalm Performance and Tech 44 11-09-2006 02:20 AM
Brakes RickRoush03 The Out House 16 09-28-2005 02:38 PM
