Rear brake switch install on vortex rearsets??? - Kawasaki ZX-10R.net
post #1 of 11 Old 07-19-2007, 07:52 PM Thread Starter
BANNED
Anyone happen to have any pictures?
Im installing the rearsets right now on my 07 zx10r and im trying to figure out how the pressure switch is installed so i can keep the function of my rear brake light from my rear brake lever? I have the rear brake pressure switch here in front of me but just dont see how to hook it up?
Let me know guys. Thanks!
Neversatisfied02 is offline
post #2 of 11 Old 07-19-2007, 08:16 PM
champ91's Avatar
Not sure what is supplied with your kit. I know Sato uses a brake line switch from Spiegler. You can see it here http://www.spieglerusa.com/cfm/BrakeAcc.cfm
It replaces the stock banjo bolt and plugs into the brake light line. Direct mount up. Works off the pressure in the line not a pull switch on the stocker.
Not sure if that helps but it could be a work around if you dont find a solution.
NESBA #456 Intermediate
champ91 is offline
post #3 of 11 Old 07-19-2007, 08:24 PM
FAF
Rent this space
I left mine off , its useful when you go past a PoPo and have to hit the anchors, no light can sometimes be advantageous.
FAF is offline
post #4 of 11 Old 07-19-2007, 08:31 PM Thread Starter
BANNED
Yeah man, never thought of that....
I will prob install it but from what booken told me, i have to bleed the brakes and all that mess and i dont have to stuff to do it right now so ill do it later. Ill just remember to grab the front brake if im stopping with traffic behind me.
post #5 of 11 Old 07-19-2007, 08:39 PM
Images: 24
Other than the above posted reason (and the occasional track day), I don't really see a lot of other reasons to even use the rear brake at all. 99% of the time I'm using the front.
Big Red is offline
post #6 of 11 Old 07-19-2007, 08:48 PM Thread Starter
BANNED
Yeah, i use the front most of the time too but i wouldnt mind having it hooked up. Oh well, no rush to put it in, ill just hold onto it until i decide to install it later down the road. Who knows, might not ever put it in.
post #7 of 11 Old 07-22-2007, 04:50 PM
Don't know if you were aware, but I talked to a guy at www.hardracing.com and he said that you have to buy another switch for the Vortex joints. They have the switch there for about $23.
shawnada1 is offline
post #8 of 11 Old 07-22-2007, 05:50 PM
10 speed's Avatar
ok have done this allot.
1st you have the 125 thread pitch corret?
2nd remove banjo bolt from top of master cyclender.
3rd clean up that mess, It eats paint! pump rear brake and clean up that mess quickly!
4th screw in the pressure switch threw the brake line coupling.
make sure you use the 2 new crush washers that came with it. {there sitting on the wires}
5th fill fluid cup with motol dot 5!!!!
6th bleed air out of lines!
7 ride!
Randy
I got tiered of buying go fast parts.... So i got a turbo! now i need go slow parts!
If it aint modded it aint yours!
10 speed is offline
post #9 of 11 Old 09-13-2011, 09:53 PM
jodyfowler3's Avatar
I am currently installing vortex race rearsets on my 07 zx10r there should be a pin that goes in the rear back bottom or a metric bolt with a locking nylon nut to secure to your vortex rearsets bottom back left hole. i am sure by now you traced the pig tails under your gas tank by now. will send pixs when done very very simple bolt on part.
jodyfowler3 is offline
post #10 of 11 Old 05-23-2012, 02:48 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
Anyone know thread pitch of rear mc banjo bolt on gen 3...Here in novascotia canada we need a rear brake light for inspections so im looking for a pressure switch..
craig_sez is offline
Anyone know how to install the "Brake pressue switch" 07Ninja1000 Performance and Tech 3 04-23-2007 05:43 PM
Attack rear set question-rear brake light switch? steves87 The ZX-10R 35 10-09-2006 04:47 PM
rear hydraulic brake switch for the 10R-$15 shipped steves87 Parts, Gear and Accessories 6 05-20-2005 05:04 PM
rearsets using stock brake light switch on1whl Performance and Tech 4 03-06-2005 03:20 PM
rear brake lite switch sticking on? scottymizt The ZX-10R 4 08-19-2004 06:27 AM
