Gen 5: 2016- Rear brake Removal ABS brake line thread size? - Kawasaki ZX-10R.net
post #1 of 2 Old 08-18-2019, 03:35 AM Thread Starter
KIXASS's Avatar
I’m removing the complete rear brake setup (drag bike) and I was wondering if anyone knows what size thread is the lines that go into the ABS module? Also into order to block off those 2 ports will the fitting need to be flared or will a bolt do the job?
Thank you.
KIXASS is offline
post #2 of 2 Old 08-19-2019, 07:31 AM
ddipaola's Avatar
If you're going to make this thing into a drag bike then just remove the ABS and all the OEM brake lines. Run one rotor/caliper and you'll be more than fine. One rotor will hold up on the street as well.
When in doubt... send it!
ddipaola is online now
