Rear Brake Caliper Upgrade - Kawasaki ZX-10R.net
post #1 of 8 Old 08-22-2008, 07:32 PM Thread Starter
Hey guys/gals,
I got the ZX14 calipers for the front, and im wanting to upgrade the rear. I know you can get the brembo caliper for the rear but it doesn't work for the stock wheels. I was thinking of using a nissin billet 2 piston caliper. Its 64mm mounting holes, and then i was thinking of just getting a bracket machined. Does anyone think this will or wont work or have any suggestions?
here is the link to the caliper:
http://www.advantage-net.co.jp/advan...CT/NISSIN.html
it is the one near the bottom of the page.
thanks in advance
Evan
evan_880 is offline
post #2 of 8 Old 08-22-2008, 07:49 PM
TotalBlackout's Avatar
don't bother, the rear brake is only slightly helpful. you lack the depth of precision with your fingers like on the front break and the back tire has almost no traction during braking due to weight transfer.
If you are using the front brakes like they are meant to be used, the rear tire doesn't really touch the ground
TotalBlackout is offline
post #3 of 8 Old 08-22-2008, 08:40 PM
CheeseHeadNinja's Avatar
You want a crappy brake on the rear, so that if you accidentally use it, it wont lock up!
CheeseHeadNinja is offline
post #4 of 8 Old 08-22-2008, 08:56 PM
KLW
BANNED
maybe he wants something that looks better, zx10 rear caliper is ugleeee, ugleist part on bike,
k
KLW is offline
post #5 of 8 Old 08-22-2008, 09:10 PM Thread Starter
yes i do want something that looks better, and i do use my rear brake in conjunction with the front one. So that what i am looking to do.
evan_880 is offline
post #6 of 8 Old 08-22-2008, 09:50 PM
Gun Owning Republican
Ervins's Avatar
Send a message via MSN to Ervins
+1...Only time I use the rear is when I think to do it and that is not often at all.
2006 ZX-10R SOLD, 2005 KX250F, and 2007 YZ85
and a Ton of Guns
I will never own a Honda again.
www.ema-usa.com
Motorcycle Parts and Accessories
Ervins is offline
post #7 of 8 Old 08-23-2008, 02:43 AM
EvoNinja's Avatar
I use it alot on hard braking and to tuck it in, in mid corner but i like to know that i've got to really step on it to make it lock so ... stock is all i need.
ZX-10R
>> scary fast
EvoNinja is offline
post #8 of 8 Old 08-23-2008, 11:25 AM
Ervins's Avatar
Yes on hard braking but aren't you happy you have the 1000RR calipers...I stopped using the rear because of this.
and a Ton of Guns
www.ema-usa.com
Ervins is offline
04-07 Rear brake caliper rated zx Parts, Gear and Accessories 0 04-16-2008 12:05 PM
Rear brake caliper flip kit thread? 9R to 10R The Out House 20 02-19-2008 01:12 AM
rear brake caliper help rojapar Performance and Tech 5 02-17-2007 11:13 AM
Rear brake caliper and bracket Mad_man The ZX-10R 4 08-19-2006 11:53 PM
06 rear brake caliper qman Vendors deals 0 08-10-2006 09:50 PM
