Rear Brake Caliper Leak - Kawasaki ZX-10R.net
post #1 of 2 Old 06-24-2010, 11:10 AM Thread Starter
slinkt's Avatar
I just changed my rear brake pads. As I was bleeding them with bel-ray DOT 4 I noticed that one of the rubber boots was bubbling brake fluid when the rear brake pedal was depressed.
Can this be fixed with new seals, or should I look for a new caliper? Leak is indicated in the picture.
slinkt is offline
post #2 of 2 Old 06-24-2010, 04:55 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
That's a new one to me man.....I would think replacing the part or a seal would fix the problem BUT i'm not sure if you can get that piece or part from an O ring/rebuild kit or not?
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
Rear brake caliper Ducati Killer Performance and Tech 9 03-01-2010 08:13 PM
08-09 Rear Brake Caliper and MC RAINMAN Parts, Gear and Accessories 2 10-18-2009 11:31 AM
05 rear brake caliper 05Green_ZX10R Performance and Tech 6 03-18-2009 01:34 PM
04-07 Rear brake caliper rated zx Parts, Gear and Accessories 0 04-16-2008 12:05 PM
rear brake caliper help rojapar Performance and Tech 5 02-17-2007 11:13 AM
