Rear Brake Bleeding problem...HELP! - Kawasaki ZX-10R.net
post #1 of 16 Old 08-02-2007, 07:16 PM Thread Starter
themightymezzo's Avatar
I have an 05 10R and purchased a set of Goodridge SS Carboline for the front and rear. Front I did first and besides breaking one of the aluminum banjo bolts I replaced it and bled all the air out and of course it works great just as expected.
Dumbass me thinking the rear was going to be easy took the old line off, put the new one on. I was a little surprised that the Goodridge line seemed to be 1-2 inches longer than the stock line. Didn't think anything of it really though. Anyway I got everything back together and started bleeding the lines. I got the air out from the bleeding valve and also did the rear banjo bolt which mounts the line to the caliper. Still spongy so of course did the frong banjo bolt on top of the master cylinder. I did these all several times as well as shaking the bike, tilting, tapping the m/c with my hand to try to get any air bubbles to the top. Of course nothing worked and the thing is still spongy as hell. I have to basically push the lever all the way down to get any feel from it. I did a search and it appears that some other people have had this problem.
Just trying to figure out if anyone was ever able to fix this situation and if so how. I'm dying trying to get back and ride the bike since I haven't been able to since breaking the front bolt, etc. Any help would be great. I know there are certain products to buy to help do this but I'm hoping I should be able to get it out with without buying anything...or at least try everything first. My wife helps so it's not like I'm struggling bleeding them.
I appreciate any help. Thanks.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #2 of 16 Old 08-02-2007, 07:20 PM
MIA Ex-Mod
Tread70's Avatar
You may need to bleed the MC by pulling the line loose and placing your finger over the hole and pump and release til you get pressure then replace the line and re bleed the system. Make sure you are adding fluid that you are taking out before it bottoms out in the reservoir also.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #3 of 16 Old 08-02-2007, 07:20 PM
FAF
Rent this space
It should be a one man job, I have to ask, have you got the washers on both sides of the banjos ?
FAF is offline
post #4 of 16 Old 08-02-2007, 07:20 PM
MIA Ex-Mod
Tread70's Avatar
Good question....
Tread70 is offline
post #5 of 16 Old 08-02-2007, 07:44 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
When u get it right post some pics i got the same lines w/EBC pads just waitng for my black gp-res. for the rear. Good luck
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #6 of 16 Old 08-02-2007, 08:11 PM Thread Starter
Yeah I have washers on both sides.
It should have pressure though no? Wouldn't taking the banjo bolt off the top of the m/c and doing what your saying be the same as loosening the bolt while holding the lever down and letting fluid air come out yield the same result?
(I can get picks probably tomorrow...they're already on...just the rear brakes don't work. Also I wasn't too impressed with the fitment at the front m/c although they do work excellent and look great.)
post #7 of 16 Old 08-02-2007, 09:42 PM
madkaw's Avatar
Pump lever 3 times and hold down
crack bleeder loose and then retighten
repeat
It does not take long to move the fluid to the caliper.
He who dies with the most toys wins!
NESBA #24993
madkaw is offline
post #8 of 16 Old 08-03-2007, 01:21 AM Thread Starter
Yeah I've been doing that exact thing. Did it with all the fittings. I will try when I get home from work later today taking the top banjo bolt off and doing it that way.
post #9 of 16 Old 08-03-2007, 02:21 AM
Nutter34's Avatar
How big is the curve at the top of the hose?
Maybe the bubbles are constantly returning to the top depending on the rate at which you are pumping them.
Is it possible to straighten the hose by having the caliper hanging somewhere with something between the pads (to stop pistons from popping out), just to see if any possible air comes out?
Just a theory of course...
Nutter34 is offline
post #10 of 16 Old 08-03-2007, 04:47 AM
Big Daddy's Avatar
Images: 38
my advice at this point is crack the banjo @ the caliper and let it seep out a bit then tighten enough to repeat the bleed procedure and i'll bet it comes around quick.
Big Daddy is offline
Brake bleeding ? dean2847 Performance and Tech 12 07-10-2008 12:20 PM
Bleeding brakes problem evallarta1 Performance and Tech 19 07-31-2007 10:43 PM
brake bleeding? am I doing this right? jblaze Performance and Tech 11 06-26-2007 11:16 PM
Brake Bleeding Emergency.....HELP!!!! Slo Poke Performance and Tech 41 06-19-2007 08:21 PM
Need help with weird brake bleeding problem Lawdog78 Performance and Tech 5 03-30-2007 03:17 PM
