really REALLY bad gas mileage after sprocket kit - Kawasaki ZX-10R.net
post #1 of 16 Old 11-07-2008, 03:03 AM Thread Starter
ok, ive got an 04 zx10r with kawasaki performance cams, pcIII, gi pro w/ atre, custom full exhaust, bmc filter, and a thinner head gasket.
i was driving it around daily getting about 35mpg city
i just had a vortex 520 sprocket kit put on and i went 2 down in the front.
i am getting the worst gas mileage now. idk how much bcuz i dont have a speedohealer yet but i can usually ride for about 4-7 days on a tank and now its like 2-3!!!
do i have to remap my pcIII bcuz of the new(front -2 down) sprocket???
fourdoorracer is offline
post #2 of 16 Old 11-07-2008, 03:15 AM
a4hiwayman's Avatar
Send a message via MSN to a4hiwayman
From what I have read on the subject of changing sprockets you will see two changes:
1. Speedo will be out by about 7% depending on change in gear ratio
2. Revs will be around 500rpm different for any given gear to achieve the same speed
As a result you will need to compensate with a speed healer to get correct mph and mileage. The engine will be running quicker and in a totally different area of the fuel mapping.. probably a richer area which would mean that you would be using more fuel.
Another big difference would be that it would change your style of riding which could well lead to higher fuel consumption.
Hope this sheds some light on it.
a4hiwayman is offline
post #3 of 16 Old 11-07-2008, 08:10 AM Thread Starter
well im more concerned about the mpg right now then any of that bcuz its my daily driver and im gonna guesstimate that its only getting like 20 mpg!!! which is a BIG problem and i need to know if theres anything i can do rather then going back to my old gear ratio?
post #4 of 16 Old 11-07-2008, 09:14 AM
beenthere's Avatar
Does the bike smell of gas or does it ever spit gasoline from the exhaust. If you have a power commander, is it working right? Consider getting it dynoed with an air/fuel ratio dyno. 20mpg does seem a bit rich, the gas has got to be going somewhere? Are the kids borrowing your gas for their mini bikes?
beenthere is offline
post #5 of 16 Old 11-07-2008, 05:07 PM
10roller's Avatar
first you should get a good figure for mpg... i reset my trip odometer every refill and i get about 38-40mpg. -1 up front. and a sprocket mod does not change engine speed.
10roller is offline
post #6 of 16 Old 11-07-2008, 05:22 PM
ZX-10R_Sinner's Avatar
He will be running higher rpms, but not high enough to cause mileage to go down that drastically. Something is wrong, I'd start checking fuel lines if really are going through that much fuel.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #7 of 16 Old 11-07-2008, 05:28 PM
Is your gas cap lock broken? Damn fuel thieves
killersrt is offline
post #8 of 16 Old 11-10-2008, 04:07 PM
ducatiryder89's Avatar
Images: 21
Do you have a custom tuned map or running a generic one? Most of the time tuners will tune lean to get more power and subsequentlly get you better MPG. A chain and sprocket conversion really should have no affect on your MPG.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #9 of 16 Old 11-10-2008, 04:30 PM
MIA Ex-Mod
Tread70's Avatar
With no speeohealer, your mileage is way off if you went from a 17 to a 15 front sprocket. You are revving higher and burning more fuel to go the same distance than you were.
If you use this bike for commuting then why the drastic change in gearing? I would either change to a -1,+1 or go for mileage all together and stay stock or go down 1 or 2 in the rear with a stock front.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #10 of 16 Old 11-10-2008, 05:08 PM
edouble's Avatar
Turn the GiPro ATRE off. With a geared bike there isnt any reason to have it. I have the GiPro ATRE and -1/+2 with a Speedohealer. With the GiPro "on" I get approx 75 miles per tank. With the GiPro "off" I get 105 miles per tank. I went through multiple tanks of gas to come to this conclusion. My bike was tuned with the GiPro "on" but that doesnt really matter as far as I know.
FYI most of my riding is in the mountains through the twisties at higher RPM's. And no I do not rev the shit out of my bike for the hell of it.
edouble is offline
Gas Mileage CP10R The ZX-10R 19 03-07-2008 02:00 PM
sprocket change increase mileage? Wind Draft Performance and Tech 10 03-28-2007 02:53 PM
Gas mileage with 16T and TRE Katmanblues The ZX-10R 23 03-27-2007 11:46 AM
04-05 mileage??? TNZX10 The ZX-10R 7 08-08-2006 08:20 AM
Gas mileage? FastAsHellZX10 The ZX-10R 8 02-09-2005 05:40 PM
