really anoying buzz noise from ignition key - Kawasaki ZX-10R.net
post #1 of 8 Old 06-17-2010, 12:12 PM Thread Starter
was wondering if it is normal for the ignition key to buzzz real load almost like a electrical piezo noise during take off and cruising speeds below 4500 rpm?
I Just bought a Brand New 2008 zx-10r on monday and it is kind of anoying.
Ichigo is offline
post #2 of 8 Old 06-17-2010, 12:14 PM
Omofo's Avatar
search and you will find the easy fix. My 1st gen buzzed, but the culprit wasn't the ignition.
Ignorance is the enemy, let's set the record straight. If history must repeat itself, why worry while you wait?- Rodney Crowell
Omofo is offline
post #3 of 8 Old 06-17-2010, 12:15 PM Thread Starter
I'll search but if i put my finger against the key it stops.
Ichigo is offline
post #4 of 8 Old 06-17-2010, 12:24 PM Thread Starter
Found a possible solution, Thanks I normaly use search just was distracted lol.
Originally Posted by espen View Post
There are connectors for the front indicators under the small plastic "dash" under the windscreen. To access them, remove the windscreen and the small plastic dash (with kawasaki on it). Try wrapping the connectors in something to avoid vibration.
A lot of people also experience buzz from the ignition lock.
Pry the "wings" (one on each side of the lock) about 1mm out so the lock will not touch, and the buzzz is gone.
Actually, I do believe the vibration in the handlebars is a lot less after the ignition fix!
Ichigo is offline
post #5 of 8 Old 06-17-2010, 12:58 PM
Omofo's Avatar
If your windscreen starts buzzing there is a fix for that too.
Omofo is offline
post #6 of 8 Old 06-17-2010, 01:21 PM Thread Starter
WoW what does this bike vibrate it's self apart
Ichigo is offline
post #7 of 8 Old 06-17-2010, 01:25 PM
Omofo's Avatar
IMO exhaust is the main contributing factor in causing bolts to come loose. As far as the 10r, Kawi must have overlooked the buzzing front end.
Omofo is offline
post #8 of 8 Old 06-17-2010, 01:26 PM Thread Starter
sounds like it lol
Ichigo is offline
fixing the "key rattle\ignition buzz" in 08, does it worth it or not TKZX General Motorcycle Discussions 7 10-09-2008 02:44 AM
Ignition Buzz?? Please help..... nite-ryder Performance and Tech 9 08-22-2008 02:38 PM
Going a little crazy.....ignition buzz. musicman Performance and Tech 21 04-08-2008 02:50 PM
'06 10R buzz/rattle from key ignition??? Jedwin The ZX-10R 20 02-16-2006 10:19 AM
