Gen 1: 2004-2005 Ran a conrod bearing - Kawasaki ZX-10R.net
post #1 of 2 Old 04-25-2013, 04:18 AM Thread Starter
zuhayr's Avatar
So I ran a bearing on one of my conrods. Had it mic'd up and the conrod is out of round and that journal's smallest diameter is 34.45 mm compared to the other three that are all still round at 34.49. My main bearings are ill still within spec at 34.99mm
I can get my conrods back to round and have my crank ground down by 0.04 mm and then plastigauge it. I am hoping that I will then have less than the 0.1 mm service limit the service manual recommends. I have ordered the blue bearings (the thickest standard bearings) but have no idea what there actual thickness is.
Does anyone have a set that they could measure for me with a micrometer?
Also any mods I should do while the motor is split?
Thanks in advance!
Black/Green 2011 ZX10R
Black 2005 ZX10R, STOLEN
MRA double bubble screen, Fren Tubo braided hoses,
Ohlins steering damper, Brembo master cylinder,
Shogun frame sliders, BMC filter, Power Commander,
Growler end can, BT 016 sticky stuff, Pazzo shorties
zuhayr is offline
post #2 of 2 Old 04-25-2013, 07:15 PM
BobFinnell's Avatar
Personally, I would replace that rod, There were forces or heat or both involved in getting it out of round that might have weakened the rod. But that is just my .
08 ZX-10r Lime Green | Full Akra | BMC street filter | Bazzaz Z-Fi W/map switch, Bazzaz Z-AFM | Secondary's Removed | GPR V4K | Scorpio i-900 | Wood Craft sliders | Roadlok disklock
BobFinnell is offline
Gen 1: rear wheel bearing/cush drive bearing question blink. The ZX-10R 2 08-25-2011 02:58 PM
Ran a 13.36! strkd50 The Out House 7 10-31-2010 09:59 PM
Conrod & crankshaft questions tasos Performance and Tech 13 02-15-2010 08:19 AM
06-07 conrod dimensions greenman43 Performance and Tech 8 11-24-2009 06:00 AM
look who i ran into!! CP10R Pictures and Videos 15 05-11-2009 09:39 AM
