Racetech Spring Help!!!!!! - Kawasaki ZX-10R.net
post #1 of 7 Old 07-25-2007, 10:35 PM Thread Starter
Exclamation Racetech Spring Help!!!!!!
JUST GOT MY SPRINGS TODAY AND INSTALLING THEM IN MY FORKS NOW. HERES THE PROBLEM THEY ARE 35MM LONGER THAN THE STOCK SPRINGS.. IS THIS NORMAL OR DO WE HAVE TO CUT DOWN THE PLASTIC SPACER?
livnpaintball is offline
post #2 of 7 Old 07-25-2007, 11:05 PM Thread Starter
Help
post #3 of 7 Old 07-25-2007, 11:32 PM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
You have to cut the plastic spacer. Just make sure you measure right and use the bottom half of the spacer - no the top - and just drill new holes.
You may want to subtract 2-4mm off your final cutting space though (meaning keep them 2-4mm longer). I cut mine to spec - at least I THINK I did - and may have to shim them. Maybe.
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #4 of 7 Old 07-26-2007, 07:29 AM
SalKhan's Avatar
Hey it's been more than 30 minutes! Where's my reply bitch!?!?
Sal Khan
SalKhan is offline
post #5 of 7 Old 07-26-2007, 08:34 AM
when i was just going to do springs instead of the whole internal kit i did a little reading and ended up ordering ohlins springs. they are oem length, just drop em in and dont have to make any adjustments.
Hoser is offline
post #6 of 7 Old 07-26-2007, 12:52 PM Thread Starter
I fell asleep waiting for you salkhan!!!!!! Thanks, gonna give race tech a call today and see if they have any height recommendations.
post #7 of 7 Old 07-26-2007, 01:31 PM
Kwaky's Avatar
If you don't get the right information there. Look up this website www.moombacyclesports.com the tech there used to be one of Racetech's Suspension Tech's and he knows his stuff VERY well. He rides an R1 but I don't hold that against him sorry the tech you should ask for is Jimmy. just tell him someone said he knows alot about Racetech stuff and say you had a couple questions. It's a VERY small shop they have some good stuff and they are VERY Fair on prices.
0510R PCIII dyno tuned 520 X -1+2 sprockets. slip on and a few other Knick Knacks filter plugs emissions dyno tune. And 20,000 miles of learning on this one anyways.
Kwaky is offline
Racetech Shock Rebuild "Kit" for 2006? SalKhan Performance and Tech 2 06-24-2007 08:35 PM
Racetech Springs only... Questions? SalKhan Performance and Tech 6 05-25-2007 04:34 AM
F/S Racetech Gold Valve Kit Hoser Parts, Gear and Accessories 4 12-19-2006 07:44 AM
Spring is Here! slide The ZX-10R 10 03-14-2005 02:55 PM
RaceTech hillcountry10r The ZX-10R 16 11-03-2004 07:18 PM
