Racefit - vibrations - Kawasaki ZX-10R.net
post #1 of 6 Old 05-07-2011, 03:30 PM Thread Starter
ScorpiusZA's Avatar
I fitted a Racefit growler a few days ago and man its loud.
It seems to run pretty lean too...I see the inside of the pipe is very light grey...and lots of popping under decel... anyhow...
..the point of this post however is that I noticed additional vibrations after I lost the std boom box and fitted the slip-on.
The boom box is bolted to a hanger which now only serves to fit the slip-on spring to.
So support for the headers is no longer and I surmise a cause of the additional vibes I'm feeling.
So I scavenged a bracket off the boom box and used a large washer which I bent to fit and tied up the slip-on/orig headers junction to the hanger and went for a spin... lo and behold minimized vibes, its now back to the smooth operator it was before... especially under acceleration.
Has anyone else noticed this with the Racefit growler?
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
ScorpiusZA is offline
post #2 of 6 Old 05-08-2011, 04:55 AM
Late Apex
Solo-Six's Avatar
perfect timing ... i tooo just did a mod using a growler .. Mine is a MGP H/B growler .. well now i have a little vibration right at the damper and i dont feel it as much as i hear it .. it sounds like its shaking the damper to pivot some .. its a solid kind of vibration aimed at the center of my top triple clamp . it did not exist before the dual can delete .. i did not bolt up the pipe after the cat to the frame mount and dont plan on it either . I am assuming this little vibration at low rpms is poor fuel management from not having a pc3 (Its on its way though)
I dont feel it in the bars or the pegs ..if its in the pegs or bars its usually suspension i think
________________Grip It And Rip It_________________
Solo-Six is offline
post #3 of 6 Old 05-08-2011, 09:11 AM Thread Starter
ScorpiusZA's Avatar
I also wondered about the possibility of poor tuning causing the vibes but its much better now..
The pipe burns quite grey though, I'm worried its too lean!
post #4 of 6 Old 05-08-2011, 08:46 PM
Late Apex
Solo-Six's Avatar
yeah .. I would think its lean if its grey
Solo-Six is offline
post #5 of 6 Old 05-10-2011, 01:10 PM
Late Apex
Solo-Six's Avatar
Yo . So i recently did a seal job and my left clipon was on a lttle loose and had some play . I tightened it a little crooked . So after i loosened it up and tightened it properly that little vibration iss GONE .. Check your clipons
Solo-Six is offline
post #6 of 6 Old 02-10-2012, 01:37 AM Thread Starter
ScorpiusZA's Avatar
aha!..good pointer, ta!
Braking vibrations Gang Green Performance and Tech 3 08-15-2008 12:42 PM
Any chicks complain about vibrations on the right peg? TI10 The ZX-10R 4 02-21-2007 02:07 AM
Vibrations?? Ultraman666 Performance and Tech 8 06-29-2005 12:20 PM
stupid vibrations BNninja The ZX-10R 5 10-05-2004 07:47 AM
Street vibrations in Reno, NV ZX-10Rrider The Out House 0 09-07-2004 12:03 PM
