race loom fitting issues gen four. - Kawasaki ZX-10R.net
post #1 of 21 Old 11-02-2014, 06:04 AM Thread Starter
Gum
I've had a quick look and have some questions. Looks like no temp sensor ????. No connections for both butterfly sensors on right side of throttle body. I have a connector that has tps written on it next to the earth wires with no tps any where near the plug. I'm sure someone has been here before and some advice may save me a lot of time.
Also do I need to buy a new fuel pump relay or can I use something from the original loom. Thanks in advance gum .
Gum is offline
post #2 of 21 Old 11-02-2014, 06:16 AM
dricked's Avatar
You'll need to buy the relay, I got mine for $30 from Superbike toy store.
Installing the harness was very straight foreward. I installed the plastic rivet that's attached to the harness in the same position the oem one was and worked my way backwards then forewards. You will have connections for both butterflies and a tps sensor. They look identical to the ones that were removed from the oem harness.
Which side of the bike did you run the harness down?
dricked is offline
post #3 of 21 Old 11-02-2014, 06:30 AM Thread Starter
Gum
I have laid it on the right side it's late here. Just had a quick look at it and posted the question. Thanks
Gum is offline
post #4 of 21 Old 11-02-2014, 08:51 AM
dricked's Avatar
You should be able to find all the connectors, they're there lol. The ones you won't have are upfront for the clutch switch, lights etc.
dricked is offline
post #5 of 21 Old 11-02-2014, 05:01 PM Thread Starter
Gum
Nope. With fresh eyes this morning. No temp sensor connector. No connectors for the the butterflys on the far right side. I have a plug near the top of shock six pin square connector using five pins. It has tps on it written by someone have no where to plug that. I've checked the part number. 26031-1219 so it should fit. I can't find any decent instructions on this. Gum
Gum is offline
post #6 of 21 Old 11-02-2014, 05:29 PM Thread Starter
Gum
[IMG][/IMG]
This has TPS written in it, cant see where it goes
Gum is offline
post #7 of 21 Old 11-02-2014, 05:30 PM Thread Starter
Gum
This plug, DO I reuse part of the old loom ?????
Gum is offline
post #8 of 21 Old 11-02-2014, 05:31 PM Thread Starter
Gum
From the left side of the engine, I take it a spare.
Gum is offline
post #9 of 21 Old 11-02-2014, 05:32 PM Thread Starter
Gum
more spares, or something from the original loom. ???
Gum is offline
post #10 of 21 Old 11-02-2014, 05:34 PM Thread Starter
Gum
have no connectors that i can see for these two connectors,
Gum is offline
Factory Race ECU and Loom wanted Gen 4. Gum Wanted: Buy or Trade 3 11-08-2013 02:50 PM
Gen 4 Race ECU & Race Loom(wiring harness). JDSZX10R o8 Performance and Tech 0 04-28-2012 10:34 AM
wiring advice for race loom. zxrjohn14 Performance and Tech 21 03-27-2010 08:16 AM
making a race loom?? zxrjohn14 Performance and Tech 10 08-06-2009 06:46 AM
race wiring loom tezzx10r The ZX-10R 2 01-21-2009 06:34 AM
