Gen 4: 2011-2015 Race kit ignition timing - Kawasaki ZX-10R.net
post #1 of 2 Old 11-18-2014, 05:20 PM Thread Starter
abadassbikerlad's Avatar
Send a message via MSN to abadassbikerlad
I have asked this before in other posts no one seems to have a straight answer.
Stock timing at max revs and advance is around 32* before tdc.
The race kit ecu shows zeros, so is different from stock to start with?
If people are flashing race kit maps to stock ecu someone must know what extra advance is used ?
2013 black uk spec gen 4, full akrapovic evo carbon, brembo rcs master cylinder, brembo clutch, ohlins race SCU, woolichracing flashed ecu with stock 02 disabled, ohlins mechatronic rear shock, Suoer corsa Sc2 200 rear smoked hot bodies rear end, Puig screen, s-2 concepts seat hump,Hell hoses, brembo m4 monoblocks samco sport red hoses, samco clamps, evotech oil cap, MWR filter, Putoline syntec 4, Jmt lion battery, nearly all bolts are titanium. 55w 6000k 2.5" Hid projectors.
190.26 hp Din
abadassbikerlad is offline
post #2 of 2 Old 11-23-2014, 10:43 AM
Eagle4's Avatar
On race ecu map "zero" is map like OEM without restriction.
Eagle4 is offline
Gen 2: Boost & Ignition Timing SpazOnaZX Performance and Tech 22 12-27-2016 08:50 AM
Gen 4: Race ecu ignition timing table abadassbikerlad The ZX-10R 0 03-15-2014 02:50 PM
Ignition timing ninja_12r2000 Performance and Tech 3 07-16-2007 10:49 AM
Ignition timing mod..? laughrun Performance and Tech 10 03-14-2007 12:06 AM
Ignition timing(fixed mechanical advancer) yvanlover Performance and Tech 7 10-20-2005 10:59 AM
