Race Kit ECU - Kawasaki ZX-10R.net
post #1 of 15 Old 08-09-2007, 01:55 PM Thread Starter
Race Kit ECU
I have the Race Kit ECU for my 06 10R and with some circuit testing I found the ECU's fan pin is "live" so I just plugged in a wire from a second kit ECU harness and my fan now works just like stock. I love this stuff!
Speedslave is offline
post #2 of 15 Old 08-09-2007, 01:56 PM
inappropriate
hesaves0211's Avatar
Images: 67
hows the performance over stock on a scale of 1-10 (10 being well worth the fuggin money!)?
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #3 of 15 Old 08-09-2007, 05:42 PM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
One of the US Mags recently did a test on the ZX-10R and said unless you have, or plan to have, motor changes or maybe running traction control, it's not worth the big money.
Can't remember the article though, I'll have to try and find it.
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #4 of 15 Old 08-09-2007, 09:19 PM Thread Starter
It is sooooo worth it. The adjustability is great. I have installed a full Akra system and been down the PC route and didn't want to go there again. I wanted a "clean" set up not a PC plugged into to my eletrical system,then get a TRE to by-pass Kawi's epa /consumer safety detunning,and now you get pinging at low rpms so you'll probably need an ignition module, you also may have to do a TPS mod and adjust your cold high idle speed. Then factor in the cost of all these and for me, the kit ECU is the way to go. Just plug it in, get tons of adjustibility,load a map and ride.
Will it add horsepower not sure, great if it does, but not the reason I went with it.
post #5 of 15 Old 08-09-2007, 10:39 PM
Dragone's Avatar
Images: 11
don't forget about the shift kill features!
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #6 of 15 Old 08-09-2007, 10:54 PM
MIA Ex-Mod
Tread70's Avatar
260310025 ECU PC Interface Cord
211750073 Adjustable ECU
What else is required? Isn't there a harness needed? I have an 04
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #7 of 15 Old 08-09-2007, 11:03 PM
Dragone's Avatar
Images: 11
You must be talking about the adaptor for the stock harness Tread.
edit: like $42
Dragone is offline
post #8 of 15 Old 08-10-2007, 12:42 PM
racrx451's Avatar
give me some dyno #'s and then we can see whether it's worth it.. I ran 163hp on the dynojet dyno with full Leo, PC III and pump gas... on my '06.
VP fuel and me.. ..adds 5 hp..
racrx451 is offline
post #9 of 15 Old 08-10-2007, 10:35 PM Thread Starter
Don't need dyno numbers to prove it's worth it to me. I've had PC and never like the set up compared to idea of a race ECU. As I mentioned above it's the adjustibility and the "clean" install without interfaces between the ecu and sensors that make it worth it. As for more hp than a PC don't know but I will shortly.
post #10 of 15 Old 08-10-2007, 11:36 PM
inappropriate
Images: 67
how much did the entire set up cost?
Race Report - Canadian(regional) RACE Superseries Round # 2: Shannonville Pro Track booneylander Track 3 05-22-2007 03:32 PM
VP Race gas in So Cal? Ara The Out House 6 03-02-2007 01:58 PM
Pilot Race vs. Power Race madkaw Performance and Tech 6 11-12-2005 02:22 PM
anyone race the 636 ???? avdigigeek ZX-6R & ZX-6RR Archives 6 10-12-2005 07:30 PM
ZX10R RACE SETTING'S.."BY KAWASAKI RACE TEAM". R1GSXRKILLER The ZX-10R 15 01-16-2005 04:34 PM
