Race Kit E.C.U. Problems !!! - Kawasaki ZX-10R.net
post #1 of 4 Old 07-19-2007, 12:43 PM Thread Starter
WRECKSHOP's Avatar
Since i installed it my radiator fan will not come on....Checked fuses, wiring, coolant level, sensor and still it will not work. So, i put the stock ecu back on to see if the fan would come on and it came on with no problems.....Please Help !!! Iceman or Deezuhl or anybody with this experience...................
WRECKSHOP is offline
post #2 of 4 Old 07-19-2007, 01:36 PM
Speed Freak
garth285's Avatar
possibly a bad ECU maybe contact dealer and see if they can help you, there arent any switches in the programming to shut off the fan so might be somethign wrong with ECU.
if all else falls you can always hard wire it to a switch.
garth285 is offline
post #3 of 4 Old 07-19-2007, 01:38 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
I bet it's normal, you would not need the fan to come on at race speeds, you bike is only gonna get hot enough to need it sitting in traffic. Thats why they call it a race ECU, is my bet. I know you can get a whole race harness as well that eliminates any unessesary plugs, you could always hard wire it in with a switch or a thermostatic switch.
9R to 10R is offline
post #4 of 4 Old 07-19-2007, 03:17 PM
LEPZ-ZX10R's Avatar
There is nothing wrong with the ECU, these kits are normally used on race bikes as mentioned earlier in this thread there is no real need for a fan on the track so the ECU bypasses the fan. Get a manual fan switch installed and make sure it is water proof such as the ones used on boats. You should not have any problems after that. Are you running a PCIII also?
LEPZ-ZX10R is offline
Problems with PM ZX10 Guy ZX-10r.net Site Help, Suggestions and Questions 16 06-11-2007 10:34 PM
Race Report - Canadian(regional) RACE Superseries Round # 2: Shannonville Pro Track booneylander Track 3 05-22-2007 03:32 PM
I have GAS problems please help ninjarollz The ZX-10R 36 11-22-2006 09:36 AM
Michelin Power race heat problems... lespaul66 Performance and Tech 22 11-10-2005 05:47 PM
Hotbodies Race Bodywork....Pics and Problems hillcountry10r The ZX-10R 15 01-18-2005 06:41 AM
