Race fuel selection - Kawasaki ZX-10R.net
 3Likes
  • 2 Post By michael4012
  • 1 Post By Nfamous60
post #1 of 10 Old 10-25-2018, 09:23 PM Thread Starter
Nfamous60's Avatar
Race fuel selection
Wanted to get some feedback on race fuel to run in my zx10. Because my competitor uses THIS forum i believe going to keep some spec hidden lol. But compression is going to be set to 13.8 to 14.0 :1. Cams headwork gasket exhaust and tuning on woolich. Not spraying nitrous but thinking bout tuning for C16 Q16 or MRX01 and thoughts or experience?. Racing would be 1mile.
Nfamous60 is offline
post #2 of 10 Old 10-26-2018, 08:17 AM
ddipaola's Avatar
Q16 supersedes C16 I believe, in terms of being able to make more power. It's a very popular drag racing fuel. It's safe to let sit in your tank too. Only con is it's almost only good when boosting/spraying. For non-stray applications your MRX01/02 might be your best bet. It's heavier on the pockets but if you can't make any power on the Q then what's the point, right? The Q16/C16 fuels have a really high octane so it's probably harder on the engine if your tune is off I'd imagine. I wouldn't neglect MR12 either... it's pretty easy on the engine. It just gums the hell outta the injectors and pump if you don't flush it before the bike sits. You could also tune for E85... just another fuel you don't want to leave in the system though, it does slowwwly deteriorate the pump.
Try out the MRX first I'd say.. Probably better to wait to hear from someone who actually drags though vs someone like me who just has friends that do..
When in doubt... send it!
ddipaola is online now
post #3 of 10 Old 10-26-2018, 10:27 AM Thread Starter
Nfamous60's Avatar
Thanks appreciate it, was told due to MR12 low octane and my compression to kinda stay away from MR12 i use to run it before. I agree with the Q16 comment not sure I'd be able to get full potential of that. MY L map is already set for E85. MY F map is pump with timing pulled incase i just want to ride around town a bit. My M map is what im focusing on for race map think MRX02 has lower octane than MRX01 not to sure but def good point of view thank you again.
post #4 of 10 Old 10-26-2018, 10:32 AM
ddipaola's Avatar
I've got problems running E85, mines set to the M mode. Is there any particular dash settings you gotta set to run it? I'm getting RPM cutout at like 10K... not sure if it's a power-mode/ECU thing or what.
post #5 of 10 Old 10-26-2018, 01:16 PM
SpazOnaZX's Avatar
C16 would be a no-go... that's something you want to use with boost/high IAT's. Great octane, but needs a lot of cylinder pressure to make it work well. Q16 is oxygenated and will likely give an increased when tuned, but it is also something that would be better for higher cylinder pressures (boost). All that said, people report back that it works well across the board for just about any application. That probably has a lot to do with it being oxygenated more than anything else.
If you don't want to try MR12, MRX02 is pretty good stuff. Look at U4.4 too... the performance of that fuel is damn good, super close to the MRX stuff, but it costs a lot less. It has a touch more octane, but is still in that oxygenated/leaded category. It really depends on how much octane you need for your set-up.... and how much timing you're willing to throw at it. People get away with MR12 (87 MON) on 13.5:1 set-ups, so 103 MON of U4.4 may be a bit much for a 14:1 build... I think MRX is in the 100 MON range. Regardless, it's all in the tuning/timing/dynamic compression. you may not be able to run as much advance with something like MR12, but it's oxygen content and the way it burns can make up the difference, and then some if you're fortunate.
Smart thing to do would be to get a pail of each and tune it out on the dyno... see which one does it for you. :)
EDIT: MS109 is in that crew too, but I don't know much about that one. It lists as unleaded though, which is a bonus for O2 sensor life. :)
SpazOnaZX is online now
post #6 of 10 Old 10-26-2018, 04:26 PM
zx racer's Avatar
I run mr12 at the track with head cam package never had problem. Good stuff!
Sent from my SCH-I545 using Tapatalk
05 ZX-10R SWB.
zx racer is offline
post #7 of 10 Old 10-27-2018, 12:58 AM
michael4012's Avatar
Im not sure why people think traditional race fuel MR12 is gonna be a problem with high compression, its designed for "race engines" a typical tune on MR12 requires 0 ignition advance.
theatiss and gaz like this.
michael4012 is offline
post #8 of 10 Old 10-27-2018, 10:40 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
I ran MR12 in my built R6 636cc motor...no issues, the high levels of oxygenation make up for the lower octane rating.
Personally I use VP Racing U4.4, its $90 per can and is the best of both worlds in my opinion. Decent levels of oxygenation and 105 octane. I use about 7-8 gallons in a typical trackday, so yes it's expensive but for my racebike, I don't want to use cheap pump gas. My Gen5 is putting out over 200hp at the wheel with a full Hindle, MWR filter and a tune. Can't ask for more!
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is online now
post #9 of 10 Old 10-27-2018, 04:43 PM Thread Starter
Nfamous60's Avatar
Are you tuned for e85?
post #10 of 10 Old 10-27-2018, 04:55 PM Thread Starter
Nfamous60's Avatar
Smart thing to do would be to get a pail of each and tune it out on the dyno... see which one does it for you. 🙂
your right thank you so much found a vp dealer here who sells by gallon Judy going to tune the diff ones expensive for dyno time but atleawon't have pails of fuel i won't usest
SpazOnaZX likes this.
Aftermarket Shock Selection tips...Penske Ohlins Elka hillcountry10r Performance and Tech 21 10-07-2010 09:53 AM
Load os Race Parts Frame Engine and huge OEM take off selection WSMC712 Parts, Gear and Accessories 36 09-08-2010 05:06 PM
Natural selection? russell The Funny Pages 9 11-23-2007 09:22 AM
Top Speed Tire Selection BryanB Race and Stunt 9 09-17-2007 01:18 AM
tire and sproket selection??? whytedude Race and Stunt 4 05-08-2006 11:17 PM
