Gen 4: 2011-2015 Race ECU TC and EB settings - Kawasaki ZX-10R.net
post #1 of 8 Old 09-22-2014, 04:21 AM Thread Starter
Eagle4's Avatar
Hello,
didi you have experience about settings for the traction control and the engine brake adjust with the Race ECu?
Wich différences with the TC mode 1 in Stock ECU and the mode 1 in Race ECU ?
Thanks
Eagle4 is offline
post #2 of 8 Old 09-22-2014, 06:13 AM
dricked's Avatar
I haven't played with the engine braking but I have messed around with the TC.
I don't think there's a difference between the oem and base kit settings. The base setting was far too intrusive but is easily adjusted. You don't play with the setting per gear/rpm it's just a simple single number change. Base setting is 0 with +5 being max TC and -5 being the minimum.
dricked is offline
post #3 of 8 Old 09-22-2014, 06:42 AM Thread Starter
Eagle4's Avatar
Thanks, anyone have tried to modify engine brake?
Eagle4 is offline
post #4 of 8 Old 02-08-2015, 03:50 AM Thread Starter
Eagle4's Avatar
Hello, back from testings (a lot) and this is some values to help settings for engine brake 1 / 2 /3 ( 4 to 6 are in 1.0 setting) on the Race ECU for the F map.
The Comp Acceleration and the Sub Throttle are also here and the constant list with my TC settings with Dunlop KR 106/108.
Have fun!
Name:	Comp map Sub Throttle.JPG
Name:	engine brake gear 1.JPG
Name:	engine brake gear 2.JPG
Name:	engine brake gear 3.JPG
Name:	comp for Accel.JPG
Eagle4 is offline
post #5 of 8 Old 02-10-2015, 08:24 PM
Is this all from within the software that IFiTec sent you when you had your ECU modified?
ZX10RArcher is offline
post #6 of 8 Old 02-11-2015, 02:39 AM Thread Starter
Eagle4's Avatar
What is Ifitec ?
Eagle4 is offline
post #7 of 8 Old 02-11-2015, 02:43 AM
Didn't you send your ECU in to them to have it changed from a stock ECU to essentially a Kawi kit ECU?
https://www.zx-10r.net/forum/showthread.php?t=251809
IFiTec was the name of the company in that thread. I thought you sent it into them...
post #8 of 8 Old 02-11-2015, 03:29 AM Thread Starter
Eagle4's Avatar
Yes, i hve a converted ECU, but not with Ifitec.
You have a PM! ;)
Eagle4 is offline
Gen 4: Race kit ECU Settings vs stock ECU abadassbikerlad The ZX-10R 1 03-15-2014 07:27 PM
Viewing Kit ECU settings JasonG Performance and Tech 1 04-10-2013 07:26 PM
Gen 4 Race ECU & Race Loom(wiring harness). JDSZX10R o8 Performance and Tech 0 04-28-2012 10:34 AM
New ZX-10 Race ECU destroyerbmx The ZX-10R 5 06-08-2010 05:15 AM
zx10r,stock & race,cam settings??? on1whl Performance and Tech 15 03-10-2005 09:25 AM
