Race Camshaft: Clarification? - Kawasaki ZX-10R.net
post #1 of 24 Old 08-04-2007, 01:53 PM Thread Starter
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
Was just going through the Kawasaki Race Parts catalog and I noticed that the Intake Race Cam Shaft states it should be used with stock springs and stock exhaust camshaft, but the exhaust camshaft needs new springs and says nothing about the intake camshaft.
Any idea what the method to the madness is?
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #2 of 24 Old 08-04-2007, 03:18 PM
BANNED
I will take a shot at this since I bought and measured all this stuff.
There are 4 different cams and 3 different springs.
Stock intake cam 9.2MM lift
Race intake cam 9.7MM lift
Stock Exhaust Cam 8.5MM lift
Race Exhaust cam 8.0MM lift
Stock intake springs 122lbs pressure
Stock exhaust springs 85lbs pressure
Race springs 127 lbs pressure.
What Kawasaki did to extract ever bit of power from the stock motor was to use lightweight Titanium exhaust valves and weak exhaust springs that work OK with lite weight valves to stop power robbing from the crank. Springs sap power from the crank. These are the weakest stock exhaust springs I have ever measured.
Funny thing is, the RACE exhaust cam has less lift so why the recommendation for stronger springs? That is the real mystery. I have emailed Attack Performance and Kawasaki HQ’s and have got no replies. No one knows the answer to this for a fact. I suspect Kawasaki just screwed the pooch.
Why a RACE cam with less lift on the exhaust? Makes no sense. I understand that this is all parts of an overall race kit package, but still makes no sense that there would be piston to valve clearance problems if you were using the race pistons. There should be plenty of relief in the valve pockets.
There is not much difference on the spring curve between the stock intake and race springs. So I would think the race intake with stock springs would be OK as long as you weren’t using a Dynojet Ignition module to increase redline. Then you might want the race springs on the intake side.
Most people who have tried the race exhaust cam lose power. No reason to wonder why. Less lift and stronger power robbing race springs.
Makes no sense.
Buy the RACE intake cam, throw it in, degree both it and the stock exhaust cam and forget the rest.
JJ
JimmyJam is offline
post #3 of 24 Old 08-04-2007, 04:01 PM Thread Starter
SalKhan's Avatar
Wow that's both impressive (your effort) and incredibly lame-slash-confusing. Did you happen to call Kawasaki at all?
Sal Khan
SalKhan is offline
post #4 of 24 Old 08-04-2007, 04:25 PM
SecretAgent's Avatar
Send a message via AIM to SecretAgent
my theory on the exhaust cam is this....although the lift is smaller the lobe seperation is changed thereby changing overlap and raising the torque curve to the higher rpm range. a smaller cam therefore also puts less of a load on the exhaust valve springs so, when combined with the raised redline that the cam is designed for, the stock springs don't have the pressure to return positively and therefore create a minimal amount of valve float.
anyways, that's just my theory. i've encountered such problems building SBC motors, i don't see why the physics would be different in a motorcycle engine.
SecretAgent is offline
post #5 of 24 Old 08-04-2007, 06:37 PM
HKMP7's Avatar
You raise the redline thats the reasons for heavier springs I got with the kit parts 13,826 rpm stock revs to 12,600 I believe not sure tho.
"MY BIKE IS FASTER THAN YOURS I CAN TEACH YOU BUT I'LL HAVE TO CHARGE"
"I've never seen the "eco" mode on my Gen 4 dash I read about it in the owners manual" : some racer
HKMP7 is offline
post #6 of 24 Old 08-04-2007, 07:06 PM
Dragone's Avatar
Images: 11
Makes no sense.
JJ
Nice. Now include the durations
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #7 of 24 Old 08-04-2007, 07:15 PM
FAF
Rent this space
Sounds about right to me.
FAF is offline
post #8 of 24 Old 08-04-2007, 07:51 PM
Speed Freak
garth285's Avatar
I believe when used all together as a kit it maybe a power adder. I was thinking since they use 14.3:1 pistons the taller pistons might need more clearance.
Ive been running stock exhaust and race intake for a long time, I Was going to try mega cycles but they are so damn expensive and you need to find good springs as well.
garth285 is offline
post #9 of 24 Old 08-04-2007, 07:54 PM
Perhaps you didn't read where he typed that he tried to contact both Attack and Kawasaki for the answers?
Kawtipping is offline
post #10 of 24 Old 08-04-2007, 08:06 PM
dsabat's Avatar
I've asked around about the kit ex cam, Doug Meyer (formerly of Muzzys) didn't know, is asking around, but it is definitely unusual.
Here's the specs with total duration.
dsabat is offline
Camshaft question on hp gains? conspiracy Performance and Tech 18 06-10-2007 03:33 PM
Race Report - Canadian(regional) RACE Superseries Round # 2: Shannonville Pro Track booneylander Track 3 05-22-2007 03:32 PM
Racing Intake Camshaft for a '04 Yui Performance and Tech 22 03-28-2007 04:51 PM
F/S Kawasaki Race Exhaust camshaft garth285 Parts, Gear and Accessories 7 02-15-2007 03:37 PM
Kawi Race Exhaust Camshaft.....anyone use it? garth285 Performance and Tech 63 09-12-2006 07:40 PM
