Gen 4: 2011-2015 Race cam marking - Kawasaki ZX-10R.net
post #1 of 10 Old 02-18-2016, 07:57 AM Thread Starter
Carlos76's Avatar
Race cam marking
Anyone having possibility to look at Gen4 race intake cam?
I need to know what is the identification marking on it (casted numbers/letters at sprocket end). Is there a paint dot too?
Seller sent me wrong item and I need to give him instruction to check for correct item.
Carlos76 is offline
post #2 of 10 Old 02-18-2016, 08:03 AM
PatrickG's Avatar
Images: 15
I can help out, I'll try and remember to look when I get home later today.
And ouch... Wrong item and shipped to Germany!! That's an expensive screw up on sellers part.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #3 of 10 Old 02-18-2016, 05:38 PM Thread Starter
Carlos76's Avatar
Bump.
Carlos76 is offline
post #4 of 10 Old 02-18-2016, 05:48 PM
mpp12's Avatar
he just have to meaure the lift....
mpp12 is online now
post #5 of 10 Old 02-18-2016, 06:12 PM Thread Starter
Carlos76's Avatar
Yes, but I need to send markings too. He may think -0.2mm (stock) is ok, when he does not know what he has.
Carlos76 is offline
post #6 of 10 Old 02-18-2016, 07:13 PM
PatrickG's Avatar
Images: 15
No paint marks or anything that I noticed between the 2 cams.
PatrickG is offline
post #7 of 10 Old 02-19-2016, 11:06 AM
gazx10's Avatar
never seen any stamp/mark/numbers/etching on any gen race cam to identify them as kit cams from the std. cams. exact same markings. last race cam i installed was purchased as a gen 3 race int. by customer for me to install in a gen 1. with identical lifts, turned out gen 1 race int. indicated by increased duration in degreeing process, gen 3 [email protected], gen 1 [email protected] duration. not gonna look at that gen 4 as patrick said and determine it to be race from stk. visually, only dial indicator/degree wheel can verify authentic. good luck carlos.
gazx10 is offline
post #8 of 10 Old 02-19-2016, 04:07 PM
mpp12's Avatar
when I had a gixxer, I had a chart and one day started making them up.... the lift was the diference really... from one another.
yoshimura of course where shinny
mpp12 is online now
post #9 of 10 Old 02-20-2016, 07:22 AM Thread Starter
Carlos76's Avatar
Thanks members for good info.
I was sure that I received a std exhaust cam, but like gazx10 said, visually there is no difference. So did measure it with dial indicator and indeed, race cam it is! Unfortunatley not intake first place.
Carlos76 is offline
post #10 of 10 Old 02-20-2016, 11:14 AM
mpp12's Avatar
That is nice....
unfortunetly, I cannot use race cams, my gasoline does not allow me to go more than a 0.5mm hg for more compression.
mpp12 is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
BGoodwin22
04-10 Kawaski Race intake cam (gen 3 cam) 08zx10rny Parts, Gear and Accessories 5 03-18-2012 07:38 PM
Gen 1: 04 exhaust cam+08 race exhaust plus intake cam seanc520 Parts, Gear and Accessories 5 11-27-2011 12:39 AM
04 exhaust cam=08 race exhaust cam..$50 tyd obo ke2012 Parts, Gear and Accessories 2 10-11-2011 04:36 AM
04 exhaust cam=08 race exhaust cam..$50 tyd ke2012 Parts, Gear and Accessories 0 08-28-2011 02:51 AM
What cam numbers for gen1 w gen3 race cam? inginekilla Performance and Tech 12 03-09-2011 07:01 AM
