Race Cam Benefits - Kawasaki ZX-10R.net
post #1 of 6 Old 09-15-2010, 06:18 AM Thread Starter
millwoodva's Avatar
Send a message via AIM to millwoodva
Race Cam Benefits
I currently race an '08 10R which is a blast to ride, but would prefer more mid-range torque.
I'm building an '09 with +3mm JE pistons and my question is.....
"Will the added duration of the kit cams aid in my quest for mid-range torque?"
millwoodva is offline
post #2 of 6 Old 09-15-2010, 07:55 AM
Gen 5 Now!!
08zx10rny's Avatar
it will probably add alittle midrange. i think that cam is for upper mid range and more top end. im waiting for my stock cams to come back from BSD performance in the UK. they did a custom grind specifically for more mid-range power for me. i would probably go with a custom set-up as well for your mods.
08zx10rny is offline
post #3 of 6 Old 09-15-2010, 09:53 AM
BratNetwork's Avatar
How much did that run you?
BratNetwork is offline
post #4 of 6 Old 09-15-2010, 10:11 AM
Send a message via AIM to Cycle Concepts
the cam profile(overall lift/duration, opening/closing rate,etc) is the biggest factor in the overall performance of the cams..a cam that is built for mid range power will yield just that...and the location of your lobe centers(degree numbers) will play a big part in where the cams will allow the engine to make power..hope this helps you..
Cycle Concepts is offline
post #5 of 6 Old 09-15-2010, 10:24 AM Thread Starter
millwoodva's Avatar
Care to share your numbers..?
I'll send mine to the UK immediately!
post #6 of 6 Old 09-15-2010, 11:33 AM
Gen 5 Now!!
08zx10rny's Avatar
it ran me about $475 with shipping both ways.
i actually using the same #'s performance bikes magazine did an article on. here is the link:
https://zx-10r.net/forum/showthread.php?t=73639. you can email BSD performance and see what they think. i was dealing with someone named Zena.
Benefits of block off plates. oldkamikaze General Motorcycle Discussions 1 04-03-2010 01:51 PM
extended swingarm benefits? daveyzx10r Performance and Tech 34 03-08-2010 05:20 AM
wat are the benefits ghost1 The ZX-10R 10 07-09-2009 09:16 AM
Are there any benefits to reverse shifting (1 up 5 down)? PumpinIron General Motorcycle Discussions 30 11-11-2008 09:33 AM
Benefits of beer Older Guy The Funny Pages 9 07-28-2008 04:35 PM
