Race bodywork help!!!!!!! - Kawasaki ZX-10R.net
post #1 of 5 Old 03-29-2009, 01:31 PM Thread Starter
DB
I just receieved my race bodywork (for an 04 ZX10r) and was looking at how the speedo cluster mounts. Does anyone have any tips or advice. Thanks!!
Dan
DB is offline
post #2 of 5 Old 03-29-2009, 01:35 PM
Green Hippie
treyzx10r's Avatar
I mounted my bodywork without having to touch the cluster,what is it you're having trouble with exactly
treyzx10r is offline
post #3 of 5 Old 03-29-2009, 03:54 PM Thread Starter
DB
When I pulled the upper fairing the cluster came off with it still attached to the fairing. I guess I need to look at it again
DB is offline
post #4 of 5 Old 03-29-2009, 04:34 PM
jblaze's Avatar
Images: 14
Did you unbolt the fairing stay that is connected to the frame instead of unbolting the fairing from the stay where the mirrors mount? That sounds like it seems to be your problem.
jblaze is offline
post #5 of 5 Old 03-30-2009, 06:48 PM
nerijusj's Avatar
Yes, upper fairing will come off with ram air tube and speedo cluster, fairing stay attached to it. You will have to take it ( cluster/ram air tube/speedo- 1 piece ) off of the upper fairing, disconect turn signal wiring, headlight wiring etc....Then you bolt it back to the frame, connect 2 connectors on left side for your speedo to work and race bodywork goes on top of that and bolts up with 2 bolts, 1 for each side, where the mirror mounts are ( center bolt-just like oem fairing ). Also 2 bolts hold the bodywork from the sides.
nerijusj is offline
08 Race Bodywork alltheaces The ZX-10R 2 12-27-2008 03:19 PM
Race Bodywork Blink180Wilhelm Vendor Deals 0 03-11-2008 03:41 PM
WTB: Race Bodywork 05Ti10 Wanted: Buy or Trade 3 07-02-2007 12:31 AM
Need Race Bodywork Help socal Race and Stunt 1 03-17-2006 08:35 PM
race bodywork bellevuetlr Wanted: Buy or Trade 1 06-09-2005 06:09 PM
