r1 master cylinder - Kawasaki ZX-10R.net
post #1 of 10 Old 05-30-2007, 07:22 PM Thread Starter
norcal10's Avatar
r1 master cylinder
anyone know if the 04-06 R1 master is a) radial b) will fit an 05 zx10r. i bought a 636 master off somebody, turns out its a 04 model, so its the same damn thing as mine. hes got an 05 r1 master he said he'd swap me for, so i might do that if its radial. thanks guys.
norcal10 is offline
post #2 of 10 Old 05-30-2007, 07:31 PM
RedNinja's Avatar
ooh yeah id like to know too
RedNinja is offline
post #3 of 10 Old 05-30-2007, 07:53 PM
Big Daddy's Avatar
Images: 38
a) yes http://www.yamaha-motor.com/sport/parts/home.aspx << proceed to parts catalog >>
b) not sure...........the clip-on diameter is most likely the same but once mounted with lines etc is where fitment issues may arise in terms of clearance when rotating lock to lock with instru, ram-air tube, bodywork etc.
Big Daddy is offline
post #4 of 10 Old 05-30-2007, 08:10 PM
ZXTOM's Avatar
As far as fitment goes....
I used a 05 GSXR1000 radial master along with 636 stainles steel lines and worked out good....
Assuming the Yamaha's is the same size fitting the 636 lines should work, by the looks of the parts fiche the postioning looks to be the same as mine....
“Accept the challenges so that you may feel the exhilaration of victory.” --General George S. Patton
ZXTOM is offline
post #5 of 10 Old 05-30-2007, 08:29 PM
topher3134's Avatar
I have one if you want one sell it cheap. I went brembo instead. It has a crg lever too.
topher3134 is offline
post #6 of 10 Old 05-30-2007, 11:37 PM
zxerboy22's Avatar
Yes it does work. You just need the lines also. It works very well I must say, as I am running this set up.
zxerboy22 is offline
post #7 of 10 Old 05-31-2007, 07:49 AM Thread Starter
norcal10's Avatar
thanks man. it looks lke i will be running 05 r1 master and calipers by next week, so i'll let you all know how it goes.
norcal10 is offline
post #8 of 10 Old 05-31-2007, 07:49 PM
Images: 9
r1 master and 04-06 cbr1000 calipers. i dont think r1 calipers will fit.
livharder is offline
post #9 of 10 Old 05-31-2007, 08:28 PM Thread Starter
norcal10's Avatar
i guess i'll find out!!! they are supposed to be bitchin because they are a monoblock design, so we'll see. got em really cheap, so if they dont work they'll hit ebay!
norcal10 is offline
post #10 of 10 Old 05-31-2007, 09:19 PM
joedirt199's Avatar
the r1 calipers will fit you just have to grind off the short sleeve that is sticking out of the mounting spots. the r1 forks have a groove that the sleeve fits in. another person on here mounted up some r1 calipers and cut those sleeves off and i believe he got them on without any real problems. should be an improvement on stopping power. i like my r1 master cylinder just need better brake pads. i went with superbike lines for the 636 on mine because i still had the stock calipers and a radial master cylinder just like on the 636. you will need r1 lines or aftermarket lines to match.
Is this where you wanna be when Jesus comes back?
Flags and handlebars should never touch the ground.
GOD made Police so Firemen would have HEROES
MODS: Homemade 1/5 throttle, -1+2 gearing, R1 Master Cyl, Galfer S/B Brake lines, 954 Handlebars, GSXR stock damper, ZX14 mirrors, gutted/shortened/ceramic coated stock exhaust, Hotbodies D/B, Ramair tube brackets, Speedohealer, flush front signals, Fake Sato rearsets, FZ1 Brembo rear master cylinder, Fender eliminated...
joedirt199 is offline
F/S -5/8 master cylinder - 04/05 10r JBJ Parts, Gear and Accessories 2 02-14-2007 10:28 PM
'05 636 Master Cylinder? zx-10r203 The Out House 1 01-03-2007 05:30 PM
636 master cylinder toedragger24 Performance and Tech 3 09-06-2006 07:38 PM
little help, rear master cylinder. hotstang46 Performance and Tech 2 08-18-2006 01:04 PM
'06 Master Cylinder Older Guy The ZX-10R 7 02-09-2006 09:08 AM
