A & R Baffle Question - Kawasaki ZX-10R.net
post #1 of 6 Old 02-24-2008, 09:56 PM Thread Starter
WhatARush's Avatar
Images: 20
WhatARush is offline
post #2 of 6 Old 02-25-2008, 12:43 PM
blackisfaster's Avatar
Did the same mod, for an 06, and do not have that problem. I do not see a hole. Maybe a pic would help. Peace
blackisfaster is offline
post #3 of 6 Old 02-25-2008, 12:51 PM
rated zx's Avatar
dont plug it, dont need the back pressure for the 10r, in fact the hole is whats gonna make the exhaust last longer due the condensation having a place to escape. also the inserts or steel and rust easy
rated zx is offline
post #4 of 6 Old 02-25-2008, 12:58 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
there is no steel in the exhaust, only aluminium and Titanium, I would plug it with JBweld if it really bothers you,I don't remembering having those holes on my stock cans with race baffles. the exhaust forces are gonna blow the condensation out the tail pipe anyway, if anything your packing may get a little wet, and cause it to break down early.
9R to 10R is offline
post #5 of 6 Old 02-25-2008, 03:09 PM
hraponte's Avatar
DO NOT PLUG THE HOLES. As mentioned before, these holes are for condensation. Unlike the stock pipes, the A & R Baffles are steel and will rust. I have two sets of stock pipes (modified, not modified) and both sets have the holes. Also, look at the position this holes are in, they blow directly into the tire's side contact patch. Maybe I'm reading too much into it, but looks like this holes were also design to help heat the tires.
hraponte is offline
post #6 of 6 Old 02-25-2008, 04:57 PM
rated zx's Avatar
the a&R baffles are steel!!!!! aluminum doesn't rust!!!!
rated zx is offline
Baffle Kit installed blackisfaster Performance and Tech 1 02-02-2008 05:19 PM
A&R Baffle Mod rated zx Performance and Tech 7 09-11-2007 04:10 PM
just bought A&R baffle Wind Draft The ZX-10R 8 02-17-2007 10:09 PM
aftermarket baffle 06blackpearl The ZX-10R 28 08-01-2006 04:55 PM
Standard end can baffle jpaterson The ZX-10R 13 07-30-2005 06:43 AM
