The shop installed my shifter and now I can't find the utility or software to change the RPM at which it activates, I have already seached through the forum and have not come up with an answer to my query.
Do I have to install a seperate software for the quickshift ? if yes where can I find it ?
yeah you can download it from DJ i think.. youll need to install the quickshift software and enable the shifter then set the Ms rate for the engine kill..
i dont have the cd off hand or i would help you.. if you call dj tomorrow they will email it to you. they did that for me when i didnt have my cd around and was using a friends pc..
CMG e-mail superbike_racing@alltel.net and I will send you the software. It is a small executable file. You execute this file with the PCIIIUSB powered up with the quickshifter attached to it. Do not open the PowerCommander control software until you have used the PC3USB Shift Kill Utility. This software adds the shift kill function to the PCIIIUSB and it will be a function under the Power Commander Tools tab if you have a Quickshifter attached. If works similar to the Accell pump utility. It is not downloadable from the PowerCommander web site.
Related Threads
Kawasaki ZX-10R Forum
2.1M posts
128.9K members
Since 2003
