Quick twist throttle - Kawasaki ZX-10R.net
post #1 of 18 Old 12-15-2010, 03:37 PM Thread Starter
DB
What is the stock throttle twist on an 04 ZX10r?
What is recommended for trackday use?
Brand name suggested?
Pros and cons?
Thanks!!
DB is offline
post #2 of 18 Old 12-15-2010, 03:37 PM
Pros and cons?
Thanks!!
Talk to rifleman, he'll hook ya up
Vortec is offline
post #3 of 18 Old 12-15-2010, 04:16 PM
Still here
ZX10Miami's Avatar
1/4 turn is stock.
1/5 is perfect- talk to Rifleman here as said.
There are no drawbacks, 1/5 turn is perfect and it should have come that way IMO.
ZX10Miami is offline
post #4 of 18 Old 12-15-2010, 04:41 PM
Of course you are faster
Rifleman's Avatar
PM sent to you DB.
As has been said the OEM throw is just over 90' degrees. With my insert that is reduced to 72' degrees or 1/5th of a turn. This is optimal for nearly all riders. Giving the full range of the throttle in one normal grip, yet long enough to give you proper throttle control in the cornors and away from standing starts.
it works equally well on the track as well as the street.
it wakes up the bike, makes it feel more responsive, agile... "tight" as some have said.
it is the way the throttle should come from the factory.
I have them in stock and can ship immediatly.
Rifleman is offline
post #5 of 18 Old 12-15-2010, 06:24 PM
jeffdort's Avatar
There are other options as well.
The KHI (Kawasaki Heavy Industries) race throttle which I've heard goes for about 500 bucks.
Similar look to the KHI is Active Throttle Kit http://www.acv.co.jp/01_product/hi_thro_en.html - which i hear is in the 150 - 200 range, comes with grips/cables/selectable pulley size ect.
if seen other variations on yoyodyne and oppracing in the 200 dollar range
But Riflemans solution is definitely the most budget friendly and gets the job done well.
I personally am seriously considering the Active cause i love the look, plus you get the cables and grips(which i need) for a reasonable price.
jeffdort is offline
post #6 of 18 Old 12-15-2010, 06:44 PM
I have a Kawasaki KIT 60* quick throttle, 1/5 turn. Its awesome, comes with new cables that are adjustable on BOTH ends, new throttle reel, and housing.
Patrick is offline
post #7 of 18 Old 12-15-2010, 06:53 PM
Still here
ZX10Miami's Avatar
Those are nice and all but Rifleman's is much cheaper and I've been using it for years with no problem. Easy enough to install too.
post #8 of 18 Old 12-15-2010, 08:06 PM
Rifleman's Avatar
Yes, the KIT 60 is actually 1/6th of a turn, it needs the additional parts to fit up properly, the OEM cables aren't long enough to get the necessary slack. I'm not sure but I think you need a larger grip housing as well. That is why those kits are more expensive. (a few hundred dollars for all the parts)
I would also put it in the "track only" catagory for most riders, it's twichy and takes time to get used to.
the 1/5th was designed with a few considerations in mind.
1. Use all the OEM parts, nothing else to buy.
2. reduce the throw to what most people can do in a single grip.
3. be reversable.
the 1/5th fits all those criteria.
Rifleman is offline
post #9 of 18 Old 12-15-2010, 08:28 PM
1madkaw's Avatar
3. be reversable.
B.S.....you will NEVER go back!!!One of the best out for the ZX 10 period. I love it!!!
1madkaw is offline
post #10 of 18 Old 12-15-2010, 09:19 PM
Different strokes for different folks - I bought my KIT throttle from a guy who used his as primarily a street bike.with occasional track duty, and sold it because he said it was too sensitive. Me personally, I think its perfect, I would even consider a even quicker throttle.
3. be reversable.
I apologize, I said 60* then said 1/5, sorry. It is indeed 1/6 turn, I guess that's what I get for typing from my phone on a rush.
The KIT throttle is more involved, however I do like the fact that its an OEM quality part that is all inclusive. Bolt it on and go.
Please don't take this as me bashing your product - that is definitely not the case. Im just trying to provide the OP with pros and cons of ALL his options.
Patrick is offline
Wheelies come at the slight twist of the throttle from 1st to 3rd MrT The ZX-10R 77 09-20-2010 11:02 PM
twist the throttle bigpat728 The ZX-10R 7 04-25-2010 01:31 PM
Twist the Throttle - 4/27 Discovery HD YSR50 General Motorcycle Discussions 10 04-28-2009 05:13 AM
Twist the throttle louemc General Motorcycle Discussions 8 04-02-2008 10:57 PM
Throttle twist adjustment hillcountry10r Performance and Tech 22 09-08-2004 11:13 AM
