quick shifter question - Kawasaki ZX-10R.net
post #1 of 6 Old 05-04-2008, 02:03 PM Thread Starter
dirt ninja's Avatar
Images: 9
I just installed the quick shifter and left it at the normal 65 ms setting and 4000 rpm shift point. I tried it out and it works okay sometimes and shitty at other times. I have to pull up hard as hell before it shifts with out the clutch. I know it needs to be adjusted so thats why im here asking those who have one. Do i need to adjust the length of the rod or change the ms? TIA
dirt ninja is offline
post #2 of 6 Old 05-04-2008, 02:11 PM
green_zx's Avatar
Send a message via AIM to green_zx
I had initial problems with mine also. Try bumping your rpm tp 7k. I did this and it stopped the problems I was having in low gears of bucking and hard shifting. Also I went to 60ms and that was easily to do. The mainm thing was the higher 7k is better. Anything below that just seems to cause problems in low gears.
green_zx is offline
post #3 of 6 Old 05-04-2008, 02:30 PM
tank zx10r's Avatar
Images: 52
i have mine at 70 and and once you bump up the rpm you shopuld be good
R.I.P Shannon T. Hightower July 29, 1971 August 4, 2007
All Kawasakis aren't created equal
tank zx10r is offline
post #4 of 6 Old 05-04-2008, 04:17 PM
Quick-shifters are intended to operate at WOT, at high-rpm. Am I understanding that you're using it at 4krpm? or did you just set the minimum there?
In any event, you don't have a whole lot of time to get your kill time set right. It's easy to damage your trans quickly if you're not unloading it enough (not enough kill time)
Bascially, if you experience "notchy" and difficulty getting it shifted, you don't have enough kill time. Too much kill time is pretty self evident, because you can feel the bike jerk. The old DJ quick-shifters only gave you one setting for all the gears. The new(er) units let you adjust for all the gears, like kit ECU's do. The taller the gear, the less kill-time you need, and being able to run varying kill times is benificial for you and your trans.
Advanced Kawasaki is offline
post #5 of 6 Old 05-04-2008, 07:55 PM Thread Starter
dirt ninja's Avatar
Images: 9
I intially set it up for 4k just for the hell of it. I changed it to 7k for now and will see how it reacts. I was going to use the quick shifter for cruising around town as well as for racing.Thanks for the input fellows!
post #6 of 6 Old 05-04-2008, 11:17 PM
SpazOnaZX's Avatar
+1 for Advance Kawi there.... the thing is only really meant for high-rpm, full throttle shifting. Stick with that, and it should be smooth as butter.
I obviously can't speak for all bikes, but you do have a fairly good window with the 06/07 10R as far as the kill-time goes. I found anything between 50ms-85ms felt identical, and had the best consistency (times and wanting to go into gear). Anything more than 90-100 started to get "jerky" as AK described, and anything less would make it "notchy" (again, good description) and increase the chance of it catching a flase neutral or just not wanting to shift at all. :)
G'luck.... make sure you find some place nice and deserted to test that thing out; it can be pretty distracting at first. :)
SpazOnaZX is offline
dj quick shifter dirt ninja Performance and Tech 1 03-16-2008 04:09 PM
question about dynojet quick shifter madnessracing Performance and Tech 14 08-27-2006 12:19 AM
i need quick shifter ali10r Vendors deals 2 07-11-2006 06:54 PM
NEED some help here DJ quick shifter phatkid The ZX-10R 12 06-04-2006 10:38 AM
quick shifter jeffzx998 Vendors deals 10 05-16-2005 11:19 PM
