Quick ? - Kawasaki ZX-10R.net
post #1 of 7 Old 07-30-2005, 07:05 AM Thread Starter
Brandon's Avatar
Send a message via AIM to Brandon
Quick ?
Im about to head to the track w/ the 10, need to pull the headlight bulbs, which are easy, what about those little fuckers in the front? is there an easy way to get them out... i havent really looked closely to finger it out, they look like they could be a PITA to get out... any info?
thanks gang..
Brandon is offline
post #2 of 7 Old 07-30-2005, 07:44 AM
instead of pulling the bulbs, why don't you just pull the fuse that goes to the lights and put painters tape over the lens?
deputydog95 is offline
post #3 of 7 Old 07-30-2005, 11:21 AM
Big Daddy's Avatar
Images: 38
yup, fuse.
Big Daddy is offline
post #4 of 7 Old 07-30-2005, 04:30 PM Thread Starter
Brandon's Avatar
why must i do everything the hard way
Brandon is offline
post #5 of 7 Old 07-30-2005, 04:33 PM
Big Daddy's Avatar
Images: 38
because we are creatures of habit.
post #6 of 7 Old 07-30-2005, 09:07 PM
Administrator
YSR50's Avatar
Images: 32
if you do want to pull the running lights, just look under the nose. there is one small screw, take it out and the panel comes off. Then just pull those two little fuggers
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
--Dr. Seuss
YSR50 is offline
post #7 of 7 Old 07-31-2005, 07:01 PM
Supercharged Mod
The reason for disabling the headlights is so that the heat doesn't melt the tape into an un-removable mess. For the main bulbs, it's an issue. For the little running lights, they're so small that the heat from them isn't a concern.
GoFaster is offline
Where can I get quick change wheel kit bbhzx10 Performance and Tech 5 05-25-2005 02:52 PM
Quick Shifters Stud_wit_style The ZX-10R 10 05-11-2005 10:20 AM
Quick Shifter setup with Gilles rearset BIKEMIKE Performance and Tech 13 04-14-2005 02:25 AM
Nitrous w/dynojet quick shifter on1whl Performance and Tech 11 03-02-2005 05:11 PM
Quick Shifter by Power Commander BIKEMIKE Performance and Tech 42 01-09-2005 10:52 PM
