Questions on removing secondary butterflies on TB??? - Kawasaki ZX-10R.net
post #1 of 15 Old 11-10-2005, 04:52 AM Thread Starter
I saw someone post about removing the secondary butterfly valves on the 04-05 zx10r...what exactly is this??? How is it done??? Advantages and disadvantages???
Anything else I need to know to do it...
Thanks
on1whl is offline
post #2 of 15 Old 11-10-2005, 07:14 AM
sneaky's Avatar
Unless they were doing some sort of turbo set up I can see no advantages at all. The electronic secondaries are used to try and boost mid range torque by altering the airflow coming into the motor.
sneaky is offline
post #3 of 15 Old 11-10-2005, 11:20 AM
Yup, it tries to keep you with the maximum volumetric efficiency possable. The point where VE max's out, is the point in your powerband where the max torque occurs. The butterflys try and change the airflow streamlines to create either presure drops, velocity change, or streamline geometry to keep the VE high during the midrange. This can get extremely complicated so I will trust that the engineers at Kawi did thier homework and found the best possable combination for our bikes.
On a side note, the VE changes when you modify intake (air filter, stacks etc) or exhaust. If you remove your butterfly's you may alter the VE for that given range that Kawi has setup for you and calculated thier stock maps in the computer for a certain VE at that point.
snoopnoon is offline
post #4 of 15 Old 11-13-2005, 08:06 PM
The secondary throttle valves have bugger all to do with "constant inlet velocity"
They are plain and simple inlet noise mufflers.
They are the best way to get a bike with huge throtttle bodies, huge air bix and huge ram air tubes past a noise emmisions test.
The stepper motor does not open the valves as fast as the engine "can" rev.
If you remove them you gain mid range power.
You will need a PC and a custom map or it will be CRAP
stocky is offline
post #5 of 15 Old 11-13-2005, 08:23 PM
sneaky's Avatar
We over here in the US do not have to worry about inlet noise as much as the british and european markets do.
You may be able to remove them, that part will be easy but how are you going to bypass the ECM functions that are going to trip the FI light once you do pull them off of the TB's?
Until I see someone reputable do a before and after dyno run with the normal A/F and DB readings then with some custom mapping then I am going to continue to think that the Kawasaki engineers know what the heck they are doing.
I am not in the hunt for all out top end hp, the best part of having the 10 is the awesome mid range punch it has, the take the secondary TB out and lose that would prob sacrafice some low to mid range TQ and take some of the fun of this bike away from it.
sneaky is offline
post #6 of 15 Old 11-13-2005, 08:40 PM
This is exactly the same setup as in the GSXR's.
You can fool the TPS to thinking the valves are still there... or you can just unscrew the valves and remove them.
If you leave the rod etc alone then the ECU doesn't know the plates are gone.
I have entirely removed them (rod and all) in my GSXR and once you get the fueling right again you don't need a dyno to tell you it's quicker.
I really couldn't be bothered chasing up before and after dyno runs and crap to post on the net but the gains are quite good.
The biggest fueling problem on te GSXR is acually about 3500 - 4000 rpm when you remove the 2nd throttle valves. The custom map fixes it.
You get more power - EVERYWHERE
This is not a one off. It also applies to the 04-05 Yamaha R1 as well.
The R1 likes them removed even more than the Gixxer.
As I said, they are mufflers.
Kawasaki, Suzuki, Yamaha engineers know best ? Well they have to pass noise and emmissions test, I don't.
Why do you think Yoshimura sell kits to remove them and/or lock them open ?
stocky is offline
post #7 of 15 Old 11-14-2005, 03:13 AM Thread Starter
zx10r butterfly removal??
Anyone done this on the zx10r???
I am going to do the mod just need instructions on what I need to remove and if I need to wire anything in or out to keep the FI light off...
LMK
THanks
on1whl is offline
post #8 of 15 Old 01-12-2006, 07:47 PM
jt76ss's Avatar
Images: 7
Send a message via Yahoo to jt76ss
Has any one done this yet????
jt76ss is offline
post #9 of 15 Old 01-12-2006, 08:23 PM
Yeah it been done to a few 10's around here. Both bikes run really good. I''l talk to them and try to get more info.
DethsZX10 is offline
post #10 of 15 Old 01-12-2006, 08:35 PM
lavudyar's Avatar
Send a message via Skype™ to lavudyar
Have to admit I'm curious myself. Besides, I like mods that work and I don't have to buy anything!
Ray D
Never pet a burning dog.
lavudyar is offline
PCIII questions K10 Performance and Tech 9 04-05-2005 04:32 PM
Talk about removing the 16 T CS NWZX10 The ZX-10R 46 03-28-2005 06:57 AM
Impressions and questions after doing my first oil change myself... deputydog95 The ZX-10R 30 03-02-2005 01:23 PM
Secondary Butterflies miykl Performance and Tech 96 01-13-2005 09:12 AM
Akropovic slip-on questions... El Diablo Performance and Tech 17 10-23-2004 04:07 PM
