Question when setting Sag - Kawasaki ZX-10R.net
post #1 of 33 Old 01-07-2009, 05:57 AM Thread Starter
Do I turn out (softest) both compression and rebound?
Or just leave factory settings?
Thank you
taxsux is offline
post #2 of 33 Old 01-07-2009, 06:48 AM
zx10forme's Avatar
When setting sag just adjust the spring preload
zx10forme is offline
post #3 of 33 Old 01-07-2009, 07:25 AM Thread Starter
I know that dude. Lol
But when I get the measurements like the rider and static sag, do I turn out all the rebound and compression to softest.
taxsux is offline
post #4 of 33 Old 01-07-2009, 08:05 AM
zx10forme's Avatar
Hey guy, sorry I goofed lol . The other settings are something you should adjust by tiny amounts,then ride,adjust,ride. First remove all weight from the forks.Take measurement. sit on bike ,take measurement.adjust for approx 25- 30 mm of movement.
post #5 of 33 Old 01-07-2009, 08:07 AM
Sag is not impacted by rebound or compression settings. You do need to "bounce" the bike a little to make sure you are getting an accurate reading and some believe softening the settings help get a better reading, but it is not needed. It's not going to hurt either way.
TN10R is offline
post #6 of 33 Old 01-07-2009, 09:25 AM
fireman69's Avatar
Very true. Do not worry about your Comp or Rebound settings, worry only about your preload adjustment. You will probably notice while setting up your bike that you will not get "perfect" static sag #'s AND rider sag #'s. you will be able to get one or the other. Don't sweat it, just get it as close as you can and ride it.
good luck
fireman69 is offline
post #7 of 33 Old 01-07-2009, 09:37 AM Thread Starter
Hahaha cheers man.
Ok guys, thanks. The stock 2005 rear shock is very stiff for my weight.. Time to invest on some Penske's I think.
taxsux is offline
post #8 of 33 Old 01-07-2009, 02:00 PM
Bigprfed22's Avatar
Images: 93
Another thing you can do which i do is dynamic average, measure initial travel(wheel extended) then sit on it with your gear.
Have someone hold you straight and one person taking the measurement. The person measuring should compress the shock and slowly let it up then measure.
Then the person measuring should lift the subframe extending the the shock then letting it down slowly, all this with you still on the bike.
Average the compressed measurement and the lifted measurement and subtract from the initial travel measurement.
"Bs stops when the green flag drops"
Bigprfed22 is offline
post #9 of 33 Old 01-07-2009, 10:51 PM
fireman69's Avatar
Your talking about measureing the stiction within the suspension. This is a great idea, but if your looking for a basic sag setup for street riding or the occasional track day, you will be very close without it.
Max Mcallister from traxxion dynamics preaches this type of setup BTW
post #10 of 33 Old 01-07-2009, 11:05 PM
Bigprfed22's Avatar
Images: 93
I thought stiction but i wasn't sure, touche.
Rear set setting question Bigprfed22 Performance and Tech 2 07-02-2008 01:29 PM
Setting up new ZX-14 AK10R ZX-14 Discussion 31 06-18-2007 11:44 AM
suspension setting question S.ga.rider The ZX-10R 6 06-01-2006 11:56 AM
Another suspension setting question! Please help!!! Chaz The ZX-10R 2 04-13-2005 07:54 PM
Setting Sag TLR2ZX10 The ZX-10R 5 07-28-2004 02:02 PM
