Question for those with full exhaust - Kawasaki ZX-10R.net
post #1 of 16 Old 04-20-2008, 07:54 PM Thread Starter
Postwhore with an 04
bcm0018's Avatar
I was installing a full exhaust and had a problem with the bracket that holds the bottom of the radiator. With the size of the new pipes the bracket doesn't fit and was wondering if anyone else had this problem and if so what did you do to fix it.
I was thinking of trying to bend the existing one but just wondering what others have done?
Thanks in advance.
bcm0018 is offline
post #2 of 16 Old 04-20-2008, 08:48 PM
axo250's Avatar
Send a message via AIM to axo250
My arata came with a different bracket for the 04.
"Besides, my ZX-10R eats GSX-Rs for breakfast." -- SportRider Magazine Article
axo250 is offline
post #3 of 16 Old 04-20-2008, 11:42 PM
it should come w/diff bracket
vjhils is offline
post #4 of 16 Old 04-21-2008, 12:13 AM
silversv1k's Avatar
Images: 44
:iamwithst
silversv1k is offline
post #5 of 16 Old 04-21-2008, 06:29 AM Thread Starter
bcm0018's Avatar
I bought it second hand from someone. I'll ask the sponsors if you can order just a bracket. Still might try to modify the original. Thanks for the input.
bcm0018 is offline
post #6 of 16 Old 04-21-2008, 08:34 AM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
What system did you order. Akra by anychance ?
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #7 of 16 Old 04-21-2008, 01:51 PM Thread Starter
bcm0018's Avatar
I got a Beet Full system.
bcm0018 is offline
post #8 of 16 Old 04-21-2008, 02:00 PM
OneSLOW10's Avatar
o you! ok ok i remember the thread and my boy OJ talking to you about us meeting up. Sorry about that. I cAn get Akra brackets but that wont work for you. Contact the guy on here you bought it from
post #9 of 16 Old 04-21-2008, 02:31 PM Thread Starter
bcm0018's Avatar
I sent him a PM. How much clearance do the akra brackets have from the pipes. My biggest problem would be getting around the springs that hold the pipes together.
bcm0018 is offline
post #10 of 16 Old 04-21-2008, 02:53 PM
OneSLOW10's Avatar
I don't think the EVO 2's will work for you since the 2's sit a lot lower then your beet if I'm not mistakin
06/07 Full exhaust or half-exhaust tuzem Vendors deals 0 11-13-2007 01:55 PM
Akrapovic full exhaust question.. Killerzxrider The ZX-10R 1 07-01-2007 04:56 PM
full exhaust question? Gutz Performance and Tech 18 07-06-2006 01:21 PM
Full Akro question Rocket Performance and Tech 11 06-06-2006 11:49 AM
Full exhaust question? Gutz The ZX-10R 3 05-17-2006 09:50 PM
