Question for Kwak Race ECU owners - Kawasaki ZX-10R.net
post #1 of 16 Old 07-18-2007, 02:04 PM Thread Starter
FAF
Rent this space
Does the ECU have Lambda ?
Cant find much info on it.
FAF is offline
post #2 of 16 Old 07-18-2007, 11:36 PM
HKMP7's Avatar
No it doesnt have any provisions for a Lambda. Do you have one let me know what I can do to help.
Cheers,
"MY BIKE IS FASTER THAN YOURS I CAN TEACH YOU BUT I'LL HAVE TO CHARGE"
"I've never seen the "eco" mode on my Gen 4 dash I read about it in the owners manual" : some racer
HKMP7 is offline
post #3 of 16 Old 07-19-2007, 12:14 AM
Rspec99's Avatar
Images: 11
I have the kit ECU and as HKMP7 said, I don't think there is a provision for a lambda.
I am still looking for the tuning link (cable), and the software for my ZX-10R, as I am still using the PC3 as a piggyback. It's just that I have a hard time justifying paying so much for the cable!
Rspec99 is offline
post #4 of 16 Old 07-19-2007, 12:45 AM
inappropriate
hesaves0211's Avatar
Images: 67
whats a lambda and how much better is the race ecu that stock? sorry to thread jack but i tried searching "race ecu" but only "race" related stuff popped up
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #5 of 16 Old 07-19-2007, 02:31 AM
Rspec99's Avatar
Images: 11
The lambda being referred is basically the provision for an O2 sensor input. Some ECU's, for example the ones used in modern cars are closed loop fuel injection, meaning that the O2 sensor measures the air fuel mixture realtime and adjusts accordingly. With emissions controls and standards, bikes will all be closed-loop EFI systems in the not so distant future I think. I think the suggestion is whether the race ECU can receive an input from an O2 sensor and operate in a self-calibration closed loop mode.
The Race ECU allows programmability and adjustments to just about every electronically governed engine parameter, including fueling and ignition timing. It can also do away with many of the "street" bike systems of the bike such as control of the secondary throttle plates, the timing retard in the lower gears, exhaust valve servo removal, and increasing the rev limiter.
I was at a dyno day a couple years back, and a local sponsored racer swapped his regular ECU with a race ECU and ran back to back runs. Now the race ECU was unmapped and unprogrammed. Back to back dyno runs yielded a 4-5hp difference. On his ZX6RR he picked up a phenomenal 9hp!
Rspec99 is offline
post #6 of 16 Old 07-19-2007, 04:58 AM
bkkninja's Avatar
My ZX10R already have the Lambda as standard! Currently removed and fitted lambda eliminators. To stop the FI light tripping. If you are using an ECU for race track purposes. U do not need the Lambda sensors. Unless your bike will be subject to CO2 testing.....
bkkninja is offline
post #7 of 16 Old 07-19-2007, 11:01 AM Thread Starter
FAF
Rent this space
The reason I asked is because I want to go closed loop , but I dont want a bike full of piggy back units controlling the DFI , I would have liked one ECM , I also dont have the room for several units as I am in the process of modifying the fuel system and I need the space for the pumps and filter.
Thanks for the input guys.
FAF is offline
post #8 of 16 Old 07-19-2007, 11:17 AM
inappropriate
Images: 67
ahha cool. thanks. how much to those puppies run well over a grand i assume?
post #9 of 16 Old 07-19-2007, 11:24 AM Thread Starter
FAF
Rent this space
near enough with all the cables required.
FAF is offline
post #10 of 16 Old 07-19-2007, 11:31 AM Thread Starter
FAF
Rent this space
I guess the stock ECU Lambda control would be out of range with a PC connected and thats why it throws the light ?
Thats why I wondered wether the Race ECU had programmable Lambda control , guess not...bummer. but for race purposes I would want it closed loop control , I have my reasons.
FAF is offline
Question for 06 penske 8981 two-way owners green_zx Performance and Tech 5 07-09-2007 07:42 AM
Question For Zx-10r 06 owners Skip114 The ZX-10R 12 12-14-2006 05:27 AM
question for S-10 owners Nick.INF The Out House 17 04-08-2006 11:09 AM
Paging LeoVince owners-have question? steves87 The ZX-10R 9 05-13-2005 08:57 AM
Hello everyone, question for ZX10 owners The Humungus The ZX-10R 28 08-07-2004 10:12 PM
