question about front sprocket removal - Kawasaki ZX-10R.net
post #1 of 18 Old 12-15-2010, 07:22 PM Thread Starter
zx racer's Avatar
hey guys does anybody know if its okay to remove the front sprocket with out the chain being installed ? and will it mess up the tranny gears any ?
05 ZX-10R SWB.
zx racer is offline
post #2 of 18 Old 12-15-2010, 07:25 PM
cyclepuck's Avatar
I wouldn't do it you can mess up the tranny. Best bet it chain on and a 2x4 in the rear wheel and bike in neutral.
cyclepuck is offline
post #3 of 18 Old 12-15-2010, 07:26 PM
bluedevil's Avatar
not recommended that's alot of torque on the internals.
bloo
bluedevil is offline
post #4 of 18 Old 12-15-2010, 07:30 PM
Gen2 Ripper
neverendingmods's Avatar
+1.. I stuck a broom stick in the rear wheel while up on a rear stand and a couple hits from an impact gun took the sprocket off no problems. There's alot of good advice in other threads about "how to remove front sprocket". Make sure you flatten the entire lock washer flat all the way around 1st with a flat head and hammer or it'll never come off. Don't do it while in gear you could fracture input shaft or screw up a gear.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #5 of 18 Old 12-15-2010, 07:41 PM Thread Starter
zx racer's Avatar
thx guys for the info ima wait till i install the chain before i remove the front sprocket. def dont wanna screw up my tranny
05 ZX-10R SWB.
zx racer is offline
post #6 of 18 Old 12-19-2010, 04:28 PM
wetley's Avatar
[QUOTE=neverendingmods;1565844Make sure you flatten the entire lock washer flat all the way around 1st with a flat head and hammer or it'll never come off. [/QUOTE]
and it may look like its flatten all the way around, but i would do a once over after your done cuz one lil spot not being totally flat and it aint ever comin off.....suuuuucks when that happens
wetley is offline
post #7 of 18 Old 12-19-2010, 06:31 PM
Nutter34's Avatar
Take it to a local dealer and ask them to do a quick loosen. Flatten the washer and it's about a minute of their time.
"You are only young once, but you can stay immature indefinitely."
Nutter34 is offline
post #8 of 18 Old 12-19-2010, 07:31 PM Thread Starter
zx racer's Avatar
i do all my work myself.
05 ZX-10R SWB.
zx racer is offline
post #9 of 18 Old 12-19-2010, 07:42 PM
Nutter34's Avatar
I don't have a compressor, never mind a rattle gun. Hence the suggestion to take it to the dealer. I don't like the idea of putting that much strain on one half of the chain, which one does when locking the rear wheel and using long bars to try and crack the nut.
Nutter34 is offline
post #10 of 18 Old 12-19-2010, 08:41 PM
Gen2 Ripper
I bought a bad ass plug in electric craftsman impact gun. No need for a compressor and airlines. Nows a good time around xmas to get 1 cheap, well cheaper than normal. The snapon cordless is bad ass too.. They come in handy alot.
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
front sprocket question... rojapar Performance and Tech 10 01-15-2010 06:07 AM
Front sprocket nut removal? clausiam Performance and Tech 30 02-07-2008 12:51 PM
Front sprocket question... Neversatisfied02 The ZX-10R 0 05-24-2007 08:54 PM
Front sprocket removal lespaul66 Performance and Tech 27 11-14-2006 09:24 AM
Front Sprocket Question IcePick06 Performance and Tech 18 12-17-2005 07:49 PM
