Question? - Kawasaki ZX-10R.net
post #1 of 25 Old 07-27-2007, 03:53 PM Thread Starter
Question?
My throttle is like a on/off switch. Its really hard to make the bike coast. Its a lot more noticable going thought the apex of a corner. If you try to coast it thought it will either accl. or decel.. Its really touchy. Is there anything I can do? Would adjusting the TPS help?
Burress8 is offline
post #2 of 25 Old 07-27-2007, 03:57 PM
WOODYZX10R's Avatar
search the site, try throttle or TRE
2004 ZX10R, mostly kinda stock
WOODYZX10R is offline
post #3 of 25 Old 07-27-2007, 04:02 PM Thread Starter
I already have a TRE. It didnt help any, I am thinking about puting a 1/5 thottle conv. on, but I dont know it that would help or hurt it.
Burress8 is offline
post #4 of 25 Old 07-27-2007, 04:47 PM
WOODYZX10R's Avatar
is your bike mapped?
post #5 of 25 Old 07-27-2007, 04:50 PM Thread Starter
No, Its bone stock. Just a TRE.
Burress8 is offline
post #6 of 25 Old 07-27-2007, 04:51 PM
Just 1st gear or all gears?
jessiah1 is offline
post #7 of 25 Old 07-27-2007, 05:13 PM
Grease's Avatar
Images: 7
Send a message via MSN to Grease
You don't really want to coast through a turn anyway. You want your throttle cracked just a little in order to transfer weight to the rear tire. If you are coasting, that means that you are probably slowing down...putting weight on the front and loading the suspension unnecessarily. The bike is actually less stable that way...
My .02
Bikes: '88 EX250 (sold), '86 Nighthawk S (sold), '03 ZX7R (R.I.P.s), '07 ZX10R (sold)
I don't like repeat offenders; I like dead offenders.
My idea of 'gun control' is putting as many bullets as I can into the same hole.
- Ted Nugent
Iím all for gun control, I just define it a little differently. If you can put 2 rounds into the same hole from 25 meters, thatís gun control!
- Jesse Ventura
God gave man a brain and a penis, but only enough blood to run one at a time. - Stephen E. Ambrose
Grease is offline
post #8 of 25 Old 07-27-2007, 06:48 PM
Nutter34's Avatar
I think a 1/5 throttle would make it worse, since you'll be applying more gas quicker. You'd have to be more precise with the throttle...
Where are you in the rev range when it's happening? Low, mid or high? And as Jessiah asked, which gears?
Nutter34 is offline
post #9 of 25 Old 07-27-2007, 07:39 PM
Dragone's Avatar
Images: 11
What about playing with your cable adjustments.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #10 of 25 Old 07-27-2007, 10:32 PM
bkkninja's Avatar
It all in the wrist. Trying twisting smoother. I had the same problem until I told myself to be smmmoooooooottthhhhh with the throttle helped. Mind you these also help. PCII + good map. GI Pro, and believe it or not a quick throttle.
bkkninja is offline
