QB Carbon Airbox for 1st Gen? - Kawasaki ZX-10R.net
post #1 of 10 Old 08-31-2008, 11:24 AM Thread Starter
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
As i was pondering my thoughts on what to do next on my 04 zx10r i came across a CF custom airbox with velocity stacks from QB world of carbon.
Has anyone used this or even heard of anyone using it?
figured it is about one of the only bolts left i can do then have it re-tuned with the kit intake cam.
jdgun_13 is offline
post #2 of 10 Old 09-01-2008, 01:20 AM
bugman53's Avatar
unless it has more volume than the stock one i dont think it will help any. if it is bigger than stock you should see a hp or two.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #3 of 10 Old 09-01-2008, 10:17 AM Thread Starter
jdgun_13's Avatar
defineately appears larger and works like my old durbahn airbox using the top of the tank for the lid and surely has more volume to it.
they used it in the BSB and world endurance racing from what i am getting told.
jdgun_13 is offline
post #4 of 10 Old 09-01-2008, 10:36 AM
Gone
thats right,larger volume and seals against bottom of tank. as used in wsb & bsb
http://www.worldofqbcarbon.com/produ...0rproducts.htm
tony83 is offline
post #5 of 10 Old 09-01-2008, 11:27 AM
bugman53's Avatar
humm.... i would say that will probally give you some gains but if it is worth the money or not its up to you. Hp per dollar is probally not that high. I do know that we had a 10 motor on a 636 with a custom airbox that was 1.5 times the size of the stock one and when we swaped the motor into a 10 with a stock air box we lost 6 hp
Greeensboro NC
bugman53 is offline
post #6 of 10 Old 09-12-2008, 01:07 AM
i had one on my zx10r dyno showed a + 6bhp yes it works but you can hear the noise under the tank
fostersice is offline
post #7 of 10 Old 09-12-2008, 12:34 PM Thread Starter
jdgun_13's Avatar
thanks for fostersice on the info, i am kind on hold right now since i may be selling the bike in order to get the ultimate bike...and it isnt a kawi
V4 anyone?
jdgun_13 is offline
post #8 of 10 Old 09-13-2008, 05:52 AM
browserzx10's Avatar
So im guessing not many people have used these carbon airboxes, im also keen to get one if its going to give good gains in HP but its a lot of cash for 1 or 2hp, id like to know what others think or have experienced?? I have done the intake cam, thinner head gasket, and full Akro evo II, and PC III, is it a worth while investment??
I didnt forget, i just didnt remember
browserzx10 is offline
post #9 of 10 Old 09-14-2008, 06:33 PM
SP8
SP8's Avatar
Probably will benefit a overbore application even more.
SP8 is offline
post #10 of 10 Old 09-18-2008, 04:23 AM
Don't waste your money. Your engine can only breathe in as much air as mechanically designed. The stock ram air box is more than enough with the exception of a highly modified motor (bored, stroked, cams, larger valves, full exhaust, etc..etc..
f4/10r is offline
Airbox Mod TurboRR The ZX-10R 7 04-12-2008 08:37 PM
Oil in airbox questions booken Performance and Tech 8 03-06-2008 10:38 PM
Question about the Airbox FastAsHellZX10 Performance and Tech 7 02-14-2008 09:22 PM
carbon airbox mr wael Performance and Tech 16 04-30-2007 04:42 PM
Racing Airbox den Performance and Tech 121 08-21-2006 11:38 AM
