Push it real good - Kawasaki ZX-10R.net
post #1 of 9 Old 12-20-2005, 08:11 AM Thread Starter
byebyebusa's Avatar
Images: 7
Send a message via AIM to byebyebusa Send a message via Yahoo to byebyebusa
Push it real good
Ok, being a former Honda guy and having very little experiance in dealing with suspension setups (Honda's the shiznet), I'm still struggling with the suspension on the ZX.. Got the sag and the dampening the way I like but I'm still dealing with a fair amount of push when hitting high speed turns. Tight stuff seems fine but those 80-100mph long sweepers are sketchy when the front end feels like it's having a mind of it's own. Any ideas or suggestions?
99 ZRX1100 - tons of mods and still slow but FUN / 07 Yami FZ1 for the wifie.
byebyebusa is offline
post #2 of 9 Old 12-20-2005, 09:40 AM
Dude your a tease with that thread title....bad bad man...
Perferd is offline
post #3 of 9 Old 12-20-2005, 09:45 AM
Are you still on the stock tires?
IdratherBzx10en is offline
post #4 of 9 Old 12-20-2005, 09:52 AM
Andy's Avatar
Images: 25
moved to tech
Andy is offline
post #5 of 9 Old 12-20-2005, 10:12 AM Thread Starter
byebyebusa's Avatar
Images: 7
Yes still on stock tires but will probably switch to Pilot Power's in a month, other than loosing a few pounds with the exhaust install and installing the dampener the bike's stock
post #6 of 9 Old 12-20-2005, 10:26 AM
Big Daddy's Avatar
Images: 38
BBB
Your experience and findings are pretty much what others have found to be true as well. Yea new tires are always nice and you'll notice an instant change in feel but i doubt it'll cure the 'push'.
Big Daddy is offline
post #7 of 9 Old 12-20-2005, 03:11 PM
lavudyar's Avatar
Send a message via Skype™ to lavudyar
Raise the rear and/or drop the front. You only need a total of 10mm(either 5&5 or 10 from one end). Then, depending on the circumference of the new tires, adjust to maintain the 10mm change.
I was gonna raise the rear when I got my Penske, but being a short fugger I dropped the front 10mm instead - huge difference in a positive manner!
Ray D
Never pet a burning dog.
lavudyar is offline
post #8 of 9 Old 12-20-2005, 08:40 PM
05Ti10's Avatar
I dropped my front to have 6MM of tube showing (including the silver cap). Before just the silver cap was above the clamp. I can feel a huge difference with just that little bit. Can't really judge until I get the new PP tires and my GPR mounted though. I have read that you should drop the front or raise the rear a bit with PPs due to the front being tall and rear shorter.
Steve
05Ti10 is offline
post #9 of 9 Old 12-21-2005, 05:13 AM
Post Whore
El Diablo's Avatar
I've taken some local sweepers at 150+ mph both with stock tires and with Powers on a 10 and never felt like it was anything other than glued to a line. The only time I've had a 10R act like the front had a mind of it's own was when the head bearings seated and got loose on Diablo. It rode like shit then, but was fine after I tightened the head bearing nut. Have you checked and tightened the head bearing nut yet? If not, check it. Maybe that could be it?
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
bad custom map vs. good custom map DB The Out House 5 11-04-2005 07:32 AM
Road racing World magazine tire test... vizsladog Performance and Tech 27 10-15-2005 11:12 AM
Hurts so good miykl The Out House 10 10-10-2005 02:34 PM
Why it is not good to cover the bike ?! baba The ZX-10R 20 02-22-2005 01:48 AM
Real? Or real HYPE?? zx102nv The ZX-10R 10 12-07-2004 03:34 PM
